- Thank you received: 301
Fog Light Wiring
- Elite Member
wcoye wrote: I have an original set of Fog King lamps without Auburn mounts (still lookin'). Is this a pipe dream, is it possible to wire these to serve both as turn indicators AND fog lamps with the understanding they couldn't be both at the same time?
You may be able to get a small bulb and socket into the reflectors and buckets (you do not have much room though), but my guess is you can find dome sort of dual filament bulb that will work to allow both turn and fogs.
- wcoye
Thanx!
Bill Coye
Westchester 2240A
Brag line: Winner of the
- wynlaidig
- Thank you received: 44
- wcoye
Bill Coye
Westchester 2240A
- Premium Member
If you use the fog lights as turn signals with LED bulbs you need to use an electronic flasher. If you use regular bulbs you are OK with a standard flasher.
- wynlaidig
brillman.com/product/12-gauge-cotton-braided-primary-wire/
If you want to integrate a ground wire:
brillman.com/product/14-gauge-double-con...raided-primary-wire/
If you do not wan to integrate a ground wire:
brillman.com/product/14-gauge-single-con...raided-primary-wire/
For wire ties: See page 12 of:
restorationstuff.com/
file:///C:/Users/Admin/Downloads/download.pdf
Aluminum ELE172 $4.00
Thanks...
