- Thank you received: 44
Hand-brake cable clamp to rear spring
- wynlaidig
24 Feb 2020 01:25 #39559
by wynlaidig
Replied by wynlaidig on topic Hand-brake cable clamp to rear spring
These photos from Bill and Gary are extremely helpful. Thank you!!
- Rileypu29
23 Feb 2020 23:39 #39558
by Rileypu29
Bill Kastanis
Replied by Rileypu29 on topic Hand-brake cable clamp to rear spring
Hi,
Attached are pictures of the hand brake clamp installed on my 812 Phaeton. The clamp is on the driver's side between the front spring hanger and the axle. The pictures are views from the front, side and rear, respectively.
Regards,
Bill
Regards,
Bill
Bill Kastanis
- Thank you received: 302
22 Feb 2020 20:44 #39552
Replied by Terry Cockerell on topic Hand-brake cable clamp to rear spring
Hi Gary. I have never seen these before but it is obvious how they are fitted.
I wonder when the Factory started using them?
After reading Section R of the Engineering Changes the clamps were not fitted to early 810s like my Cord ................................... interesting.
22 Feb 2020 20:33 #39551
Replied by 1748 S on topic Hand-brake cable clamp to rear spring
I'm not able to get under the rear of my car but maybe this might help you.
- wynlaidig
22 Feb 2020 15:24 #39549
by wynlaidig
Hand-brake cable clamp to rear spring was created by wynlaidig
Does anyone have a photo showing how the hand brake cable is attached to the rear spring? Page 37 of the engineering changes (Section R, dated 2/17/37) describes clamp #R10939 which attaches the cable to the 3rd section of the rear spring cover. But it's a bit confusing. A picture would be very helpful.
