- Thank you received: 18
Can't remove interior door latch handle and window crank handle after removing t
- thomaslee
25 Feb 2020 16:54 #39578
by thomaslee
Replied by thomaslee on topic Can't remove interior door latch handle and window crank handle after removing t
This is a copy of directions sent along with the locking part made by Henry Portz
I'm posting this from George van Nostrand
- wcoye
17 Feb 2020 15:22 #39521
by wcoye
Bill Coye
Westchester 2240A
Brag line: Winner of the
Replied by wcoye on topic Can't remove interior door latch handle and window crank handle after removing t
Thanx!
After an additional 2 hours+ I got it off . Had to destroy the escutcheon to get the crank off but they are relatively cheap, if you shop around
Bill Coye
Westchester 2240A
- STEVEN.KUIPER
- Thank you received: 17
17 Feb 2020 13:41 #39519
by STEVEN.KUIPER
Replied by STEVEN.KUIPER on topic Can't remove interior door latch handle and window crank handle after removing t
put a tiny bit of 3in1 oil in the pin holes. if your interior is nice it could be a challenge not to get oil on the fabric. wait a day or two. then wiggle handles up and down while pulling. for more leverage, wrap some cloth around handle then gently clamp on a vice grip ....wiggle & pull.
- wcoye
15 Feb 2020 20:32 #39511
by wcoye
Bill Coye
Westchester 2240A
Can't remove interior door latch handle and window crank handle after removing t was created by wcoye
Howdy and happy coooold Saturday! I'm removing the window cranks and latch levers from the interior of my car. I've run into several that will not budge after popping the pins out. I need suggestions on how to free up these handles without destroying them. Help?
Bill Coye
Westchester 2240A
The following user(s) said Thank You: Martin01
