horn drive system
03 Feb 2020 19:21 #39453
by uconn_1965
Replied by uconn_1965 on topic horn drive system
I didn’t mention the “button” on the end of the horn wire going down the steering tube Because it’s part of the wiring. The small spring I mentioned goes over this button. The rubber bumpers you mention are not original but they do help prevent the center horn cover from chipping when the horn ring is depressed.
03 Feb 2020 19:03 #39452
Actually a few more pieces are missing. I do have the nut and washer. Just did not post pics of them. But I'm missing the bronze spring, wire harness and the rubber bumpers under the horn button cover. I saw a picture from Stan that clearly shows everything. I believe Stan sells the information sheets for $3.00. I recall one of them was info sheet #93 but I did not find that in Stan's catalog. I also checked Rhode Island wire and they do NOT list this harness piece. I have not called them yet to see if the horn harness is included in the main under dash harness.
Replied by 1748 S on topic horn drive system
uconn_1965 wrote: Missing nut, washer, and small spring.
03 Feb 2020 14:57 #39451
by uconn_1965
03 Feb 2020 00:51 #39449
This is all I have to my horn. I believe something is missing about the contacts. Sadly I have not purchased that wire harness from Rhode Island yet. May order it by end of month.
- fleibel
01 Feb 2020 17:05 - 01 Feb 2020 17:07 #39439
by fleibel
Replied by fleibel on topic horn drive system
Last edit: 01 Feb 2020 17:07 by fleibel.
01 Feb 2020 15:32 #39435
I can take some pictures of my horn ring and Assembly pieces because its in pieces during restoration.
- fleibel
01 Feb 2020 11:25 #39433
by fleibel
horn drive system was created by fleibel
Good Morning, I would like to know if anyone has the assembly diagram and photo of the parts of the horn drive system on the steering wheel? The fixing button that is in the center of the steering wheel if possible with a photo showing how the back is.
Tks a lot
Tks a lot
