Front Brake Hose
  • wynlaidig
04 May 2021 13:12 #43043 by wynlaidig
Replied by wynlaidig on topic Front Brake Hose
If the hose is supposed to go under the arm per Cord bulletin #24, the perhaps the cylindrical rubber piece shown the above photo is mounted "upside down". If the clamp remains in the same place as shown in the photo, but the arm was passed through the rubber piece before being mounted, then the hose could indeed go under the arm. Can anyone confirm that this would be correct?
04 May 2021 14:21 #43047 by uconn_1965
Replied by uconn_1965 on topic Front Brake Hose
On the last Cord I put together, this is how I ran the brake hose, it always goes under the trailing arm. My set up has been modified a little bit for this driver. When I ordered the new front brake lines, I was disappointed that they have really cheapened them up, no wear near as “hefty” as originals. When installing I added an additional rubber hose and zip tied it together
  • George van Nostrand
  • ACD Club Member
  • ACD Club Member
05 May 2021 14:57 #43058 by George van Nostrand
Replied by George van Nostrand on topic Front Brake Hose
Wyn You are correct.
  • Terry Cockerell
  • Terry Cockerell's Avatar
  • Frequent Forum Contributor
05 May 2021 22:26 - 05 May 2021 22:28 #43061 by Terry Cockerell
Replied by Terry Cockerell on topic Front Brake Hose
It appears that the rubber hose in the attached picture is too large in diameter.
The metal clamp and its position are ok. The brake hose has to loop down under the trailing arm as per Service Bulletin No 24
Last edit: 05 May 2021 22:28 by Terry Cockerell. Reason: Adding picture
  • Terry Cockerell
06 May 2021 04:52 - 07 May 2021 11:29 #43070 by Terry Cockerell
George Van Nostrand tells me that the rubber hose is slid over the steering arm and the brake line . The clamp just holds the rubber hose in place.
I will get to check this out on my Cord in the not too distant future and post pictures.
The attached picture arrived from George, it shows how the Factory did it.
Thanks George.
Last edit: 07 May 2021 11:29 by Terry Cockerell. Reason: Adding picture
Time to create page: 0.194 seconds
