Danger Warning
23 Jul 2019 15:25 #37853
by uconn_1965
Replied by uconn_1965 on topic Danger Warning
I stand corrected. The rear brake hose is 17 1/2” long and the fronts are 21” long. However I found that I still wasn’t getting any clearance from the hose to the tire rim. The problem ended up being the front wheel stops. Somewhere along in production there was a service bulletin recommending changing the wheel stops to 2 1/16”. When I did that, problem solved. Apologize for the erroneous warning.
22 Jul 2019 00:58 #37846
by uconn_1965
The original front brake hoses are approx, 17 1/2” long. The ones I purchased are longer and that creates the problem. Originally they are held out of the way by a metal clip that holds a rubber band that attaches to the steering arm that attaches to the backing plates and keeps the brake hose positioned correctly..
22 Jul 2019 00:23 #37845
Replied by 1748 S on topic Danger Warning
Thanks Cliff. I have been "watching them" for years. Never intended on purchasing them but great to know. I recall we need aluminum straps securing to brake hose to the steering linkage too. I have pictures of an unmolested 37 supercharged Cord sedan from overseas being taken apart. I recall it was Slumphs or something sounding like this....
21 Jul 2019 19:11 #37840
by uconn_1965
Danger Warning was created by uconn_1965
If you bought the front brake hoses for a 1936-37 Cord that have been advertised on Ebay - WARNING, although they look correct but are longer than the original brake hoses, when you install them correctly so that they go under the trailing arm, you will find that when you turn the wheel fully either left or right, the brake hose rubs against the inner rim of the tire........an accident waiting to happen.
