Correct hose clamp(s)
29 Dec 2019 06:41 #39121 by tayedils
Replied by tayedils on topic Correct hose clamp(s)
wcoye wrote: Hi! Recently had a manifold repaired. When it was re-installed the guys used a worm drive clamp to cinch-up the asbestos sock on the exhaust line immediately after the manifold. That can't be correct, but what is. Is there a list I've missed for the proper clamps for the rest of what is under the hood? I thought I'd spend rainy summer days sprucing up the engine bay. Correcting the clamps seems to be a worthy project.
The hasteners were simalar to the design of the Speed Test Scrabble Word Finder Solitaire under hood wire fasteners along the radiator supports that held the horns.Stan sells them.
19 Jul 2022 17:18 #45715 by abhaysingh
Replied by abhaysingh on topic Correct hose clamp(s)
Jim, I have pictures of the rope I've seen in years past meeting the West Coast in Morro Bay. It was an original uninfected car. Mark Tommy was looking under her. I was asking Randy Emma about an extra copper tube extension for the oil cap area of the disposal bearing. Ron Erwin also requested Randy that was the original extension. vnvideoeditorpc.com/
19 Jul 2022 20:16 #45716 by 1748 S
Replied by 1748 S on topic Correct hose clamp(s)
I was at that West Coast meet. I too saw this unmolested Cord. I was standing with Randy and Ron and asked Randy the same question about the oilier for the throw-out bearing.Ron said it was NOT original. Also the rear bumper has an extra stiffener piece added for the tow hitch. It too was not original. The asbestos pipe insulation on the exhaust header pipes was original and it was held to the steel pipe with band clamps. The same pipe insulation can be made today using a material called calsil. It comes in different thickness and pipe size up to about 30 inch diameter. Its common in power generating steam plants. I used it plenty in the distant past.
04 Aug 2022 20:13 #45808 by BobbyR
Replied by BobbyR on topic Correct hose clamp(s)
Years ago Melvin Clemens was told a worm drive hose clamp was not correct of
J357 and his answer was "It doen;t leak anymore"
Bob Roller
  • mikespeed35
  • mikespeed35's Avatar
06 Aug 2022 04:05 #45815 by mikespeed35
Replied by mikespeed35 on topic Correct hose clamp(s)
Right on Bob. Do you want to drive or look pretty.
06 Aug 2022 07:42 - 06 Aug 2022 07:43 #45817 by Terry Cockerell
Replied by Terry Cockerell on topic Correct hose clamp(s)
Mike you can have both. Some of the period style clamps I bought would not close up enough to suit the hoses on the engine. I simply made my own period looking hose clamps. The brideg the gap I fitted a small stainless steel strip with both ends tapered. They look good and don't leak.
Last edit: 06 Aug 2022 07:43 by Terry Cockerell. Reason: Adding picture
Time to create page: 0.048 seconds
