Original Pedals
- ACD Club Member
06 May 2019 16:30 #37154
Original Pedals was created by 1748 S
Can anyone post pics of the original throttle and brake pedals? Am not sure if mine are correct. My throttle pedal is a Fulton. Thanks...
- Michael R
- Forum Contributor
- Thank you received: 18
07 May 2019 16:45 #37157
by Michael R
Replied by Michael R on topic Original Pedals
- Frequent Forum Contributor
- Thank you received: 139
07 May 2019 22:39 - 08 May 2019 09:09 #37160
Replied by Terry Cockerell on topic Original Pedals
To the best of my knowledge the brake and clutch pedal rubbers are correct however the accelerator pedal should be slightly pointed at the top. The accelerator pedal supplied by Stan has the same general shape but it has a bend near the bottom whereas it should be flat. I have attached a sketch of the pedal supplied by Stan ................. it will do the job. When installing the accelerator pedal I had to make longer than standard ball ended bolts for the pedal to engage with. Floor insulation was probably the root cause.
Last edit: 08 May 2019 09:09 by Terry Cockerell. Reason: Spelling error
- ACD Club Member
- Thank you received: 92
08 May 2019 12:36 #37163
Replied by Curt Schulze on topic Original Pedals
What is the reason for the bend in the lower part of the gas pedal? I have sold gas pedals and pedal pads for Auburn & Cord for years, this is a new one for me.
08 May 2019 20:51 #37164
I have no idea why the bend is there . It is the pedal supplied by AC Parts these days according to Stan.
- ACD Club Member
08 May 2019 22:16 #37165
Replied by 1748 S on topic Original Pedals
This is the pedals I have.
Time to create page: 0.326 seconds
