- Thank you received: 44
Bendix brake assembly
- wynlaidig
30 Oct 2018 00:14 #35855
by wynlaidig
Replied by wynlaidig on topic Bendix brake assembly
Thank you so much Dan. The photos are very helpful.
- Dan DiTullio
29 Oct 2018 23:07 #35854
by Dan DiTullio
Replied by Dan DiTullio on topic Bendix brake assembly
- wynlaidig
20 Oct 2018 17:17 #35766
by wynlaidig
Thanks for the photo, 1748S. If anyone has a complete photo of the Bendix rear brake system, that would be especially appreciated.
19 Oct 2018 03:45 - 19 Oct 2018 03:46 #35746
Replied by mikespeed35 on topic Bendix brake assembly
You may want to check with other people about modern linings. If they are used on L-29 they will squall something offal.
CORDuallyMike
CORDuallyMike
Last edit: 19 Oct 2018 03:46 by mikespeed35.
18 Oct 2018 15:42 #35732
Replied by 1748 S on topic Bendix brake assembly
This is what I have available. I had both front side brakes relined with non asbestos non riveted lining by a shop in Long Beach Ca. named Friction Lining. They have been around for about 60 years. They also refaced my clutch disc and rebuilt my pressure plate. Am very happy with the work.
- wynlaidig
18 Oct 2018 14:21 #35731
by wynlaidig
Bendix brake assembly was created by wynlaidig
Could someone post photos of the front and rear Bendix brake assemblies, showing correct springs, shoes, and cylinders?
Also, I understand that the correct Bendix brake shoes were #263, which is also what I have seen. But when did this change place? The last engineering note I can find on brake shoes is dated 12/31/36 and says "Changing all brake shoes on Bendix. Raybestos #451 Front or Primary Shoes. U.S. Asbestos #589F on rear or Secondary Shoes." #451 and #589 don't look anything like #263, so there must have been a later change. Anyone know when this happened?
