Gas Tank Level Sender
21 May 2018 21:10 #34671
Replied by mikespeed35 on topic Gas Tank Level Sender
Talked to Wolf today. They don't know specs for 810-12 Cords.
They could repair yours if you have one.
21 May 2018 03:55 #34670
Wolf will probably know.
- Premium Member
20 May 2018 19:52 #34668
Replied by JIM.OBRIEN on topic Gas Tank Level Sender
I have a guess right now but was wondering if anyone knew the correct numbers. I don't have any resistors big enough to check through the meter. I guess I'll figure it out and post the results..
20 May 2018 06:03 #34666
Replied by 1748 S on topic Gas Tank Level Sender
Jim with that many possibilities how can you get the correct sender? Is there any way you can "feed" the dash gauge to figure out what ohms you need? I'm only guessing here because I have not gotten this deep in the sending units with ohms....
20 May 2018 04:41 #34665
John Wolf and Co. In OH. Phone 440-942-0083. He is in Hemmings. Look on page 148 in the June issue bottom right.
- Premium Member
19 May 2018 21:45 #34664
Mike,
Can you give me some info on Wolf? I have not heard or used them. The 0-120 ohm won't work in the Cord - it would read backwards. There were several different standards that were used back them including 0-30, 30-0 , 0-120, 30-140, 140-30 and I'm sure there are others.
19 May 2018 04:02 - 19 May 2018 04:04 #34660
You might try Wolf Jim. Just got one for my Marmon from him. It was 0 to 120 Ohms. It sounds like that was a common value for 6V gauges. He needs to now tank depth.
Last edit: 19 May 2018 04:04 by mikespeed35.
19 May 2018 03:09 #34659
Sorry I don't know this but Jim I do have some posts showing the sender all taken apart.I was cleaning mine of years of dirt sitting forever. Surprisingly the engine oil level sender is very similar internally too. I also have that one open on my shop bench.
- Premium Member
19 May 2018 01:48 - 19 May 2018 01:49 #34658
Gas Tank Level Sender was created by JIM.OBRIEN
Does anyone know what the resistance is for the fuel level sender? I need to order a new one and I don't remember the Spec's. The last time I ordered one - about 25 years ago I got the wrong one and my gauge always read backwards. But I can't find the spec's on what I ordered back then.
Thanks.
Thanks.
Last edit: 19 May 2018 01:49 by JIM.OBRIEN.
