A Newbie and puzzled.
02 May 2007 05:45 #6965
by Josh Malks
Replied by Josh Malks on topic A Newbie and puzzled.
Good call, Henry. The holes are there, but (at least on the visible right side) it's being used for a wire. Randy will find out what the hoses are for the first time it rains. <!-- s:wink: --><img src="{SMILIES_PATH}/icon_wink.gif" alt="" title="Wink" /><!-- s:wink: -->
- hportz
02 May 2007 03:15 #6963
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic puzzled
Doesn't it rain in Portland? Where are your hood hinge drain hoses?
01 May 2007 20:42 #6956
by Josh Malks
That could be an ACD Company plate, or even more likely a later repro plate. It is the later version, with two patent numbers engraved (not die-stamped) into the plate. Whoever replaced it after the paint job used phillips-head screws --- a no-no.
Another tip. Your car uses a starter solenoid instead of the original Startix. The only problem is where it is mounted. The position it is in appears to add several feet to length of the battery and starter cables, and that ain't good. See of you can relocate it to the original Startix position, use #00 welding cable with professionally crimped (not soldered) terminals, and be sure there is another such cable from the battery ground terminal to one of the starter mounting bolts. Bet that speeds things up.
- Randy in Portland
01 May 2007 19:38 #6955
by Randy in Portland
First Round, First Minute....Muhammad Ali
Replied by Randy in Portland on topic some images I had here at work, Thank you.
[img][img]http://img.photobucket.com/albums/v660/PortlandRider/IDTAG2.jpg[/img]
[img:3oa0238s] img.photobucket.com/albums/v660/PortlandRider/RightFirewall.jpg [/img:3oa0238s]
[/img]
[/img]
01 May 2007 18:12 #6954
by Josh Malks
I think you listed your serial number incorrectly. I think it should be 812 31874A.
If that's the case, the car is known. It's listed in my book on page 258, last line. It was originally a supercharged Westchester (itself a rather rare car) whose original engine, FC2595, was replaced with FB375. Since the serial number plate was replaced too, the likely culprit is the ACD Company in 1960 or earlier. (They made new plates from their stock of blanks when they replaced an engine.)
As for the clearance dent for the rear fuel pump, please look again. The dent is not very large. See if you can get a photo for us of that area.
- Randy in Portland
01 May 2007 15:50 #6950
Replied by Randy in Portland on topic A Newbie and puzzled.
Please pardon my earlier omission:
The Identification tag says:
Model 812
Serial number 31374 A
Central Mfg. C90 1514
Engine FB375
Model 812
Engine FB375
01 May 2007 15:29 #6949
by Josh Malks
When you get home check the tag. There is more to the number --- that's why I asked for all of it. It should have 810 or 812 in the previous field, and a letter after the number you gave. Let us know.
- Randy in Portland
01 May 2007 15:01 #6948
Serial number 31374
Engine FB375
I am at work and currently have access only to a picture of this tag.
Serial number 31374
Engine FB375
01 May 2007 13:39 #6943
by Josh Malks
What is the serial number of your car? (All of it)
- Randy in Portland
30 Apr 2007 22:56 #6940
A Newbie and puzzled. was created by Randy in Portland
I recently bought a 37 Westchester. I don't know a lot about these cars but love learning. Bear with me, please:
Two things exist on the car that puzzle me. I have an electric fuel pump under the tank and the original fuel pump is currently bypassed. But, the original is located on top of the block near the carburetor.
Also, the toe in the firewall area has no indentation where a fuel pump at the lower block would be located.
Is this configuration commensurate to a 37? I have heard that all 37's had the lower fuel pumps and the modified fire wall.
Thanks for your advice.
