Cam Bearings
- Ric Simpson
02 Apr 2007 00:55 #6730
by Ric Simpson
Ric Simpson,
2001 Niagara Parkway,
Fort Erie, Ontario,
Canada. L2A 5M4
Replied by Ric Simpson on topic Cam Bearings
Hi! I'm not sure about the answers you have received? Mine were a single shell, pre-babbited, that you press into the block. I believe there are 5 and they are each different in diameter. I remember the panic I had when my engine machinist told me the centre main was too lose in the block. I had bought my set 20 years earlier from a member, and had no idea where to buy a replacement. My machinist said it wasn't a problem! He had already bought a replacement from the local parts supplier and installed it! I wish I had asked him where and what it came from. It was 20 years ago, so I can no longer ask him. I believe after inserting the bearings, they were line bored to the correct finish sizes. Whatever, they have served me well and I trust they will be just as fine now the cars body has been re-restored. Ric.
Ric Simpson,
Fort Erie, Ontario,
Canada. L2A 5M4
02 Apr 2007 00:47 #6729
by
Replied by on topic Cam Bearings
Dan,
You can buy replacement bearings that are semi-finished that you can drive in place. You then have to line bore them to the finished size.
- mopar4ya
02 Apr 2007 00:07 #6728
by mopar4ya
Replied by mopar4ya on topic Cam Bearings
So they have to be poured in the block,or you buy a replacement and drive in the block?
Dan
Dan
- E L
- Thank you received: 25
01 Apr 2007 23:12 #6727
by E L
Replied by E L on topic Cam Bearings
cam bearings are a split shell that is pressed in and are lined with babbit
- mopar4ya
01 Apr 2007 18:09 #6724
by mopar4ya
Cam Bearings was created by mopar4ya
I would like to know if the cam bearings are a drive in type replacement or were these a Babbitt type bearing that has to be poured in the block. If they are a drive in type, who sells new ones.
Dan
Dan
