Exhaust Manifolds for a 812SC Wanted/Engine hardware?
- e merancy
17 Mar 2007 22:50 #6593
by e merancy
Replied by e merancy on topic S/C exhaust manifolds
See item # 190093390719 on EBay they look pretty good to me Good Luck Ed.M.
e.merancy email
- Mark Tomei
12 Mar 2007 05:41 #6553
by Mark Tomei
Replied by Mark Tomei on topic Exhaust Manifolds for a 812SC Wanted/Engine hardware?
Thanks for the information . I am hoping also on the nut and bolt front that there might be a simpler idea than machining new ones myself.
- hportz
12 Mar 2007 03:42 #6552
by hportz
www.portzcordz.com (photos)
Replied by hportz on topic S/c exhaust manifolds
Your 2nd question; go to ACD Club Forum Index "Judging Information"
- hportz
12 Mar 2007 03:30 #6550
by hportz
Replied by hportz on topic S/C exhaust manifolds
You can get the manifolds from Don Simmons & sst'l exhaust system if you like. 519-485-1966
- Mark Tomei
11 Mar 2007 05:45 #6547
by Mark Tomei
Exhaust Manifolds for a 812SC Wanted/Engine hardware? was created by Mark Tomei
Can anyone help me on where I might find a set of '37 812 SC outside pipe Phaeton exhaust manifolds?
One last question for now on the esoteric side; Are the correct bolts used for the exposed engine assembly available? Is there a judging standard that I should attain?
I think the Forum you folks have is splendid. Actually, it's the only place I have found that actually, collectively, knows anything for certain about these cars!
[/code]
[/code]
