torque pressure for rod bolts
- danooo7
- Junior Member
11 Aug 2006 03:46 #5203
by danooo7
Replied by danooo7 on topic rod bolts
Mike, thank you for your input. I will give it a try. I've had my engine balanced prior to fitting all the machined parts together. I think as long as all finished piston assemblies are weighed and equal in weight that should work. Thanks again Dan
- Mike Brady
10 Aug 2006 11:40 #5194
by Mike Brady
Replied by Mike Brady on topic torque pressure for rod bolts
Dan:
Chrysler 383 or 440 rod bolts can be used as replacements for the 810 & 812 Cord. The Chrysler rod bolts are slightly larger in diameter so you will have to ream the bolt holes in your rods so they fit. I purchased my rod bolts from ARP and torqued them to 50 lbs.
CORDially, Mike
CORDially, Mike
- danooo7
- Junior Member
10 Aug 2006 01:35 #5193
by danooo7
torque pressure for rod bolts was created by danooo7
Again I need your help in restoring my '37 Cord standard engine Beverly. My question is what is the proper torque pressure (in ft/lbs) to tighten my connecting rod cap bolts? Also I've discovered that some of the bolts need to be replaced so I will get a new complete set, but where? Any help is always appreciated. Dan
