- Thank you received: 44
Center Header Bow latch question
- wynlaidig
06 Feb 2023 02:42 #46773
by wynlaidig
Replied by wynlaidig on topic Center Header Bow latch question
I have a later 1937 phaeton which has the original header and all the latch backing plates are indented exactly the same as in the 1936 models.
- THOMAS.BRETHAUER
19 Jan 2023 21:44 #46699
by THOMAS.BRETHAUER
Replied by THOMAS.BRETHAUER on topic Center Header Bow latch question
Here is a picture of my whole assembly, latch plus brass plate. My brass plate is not inset into the header, but it is a 1937. Plate measures 5 x 1 3/4 x 1/4 inch.
- Thank you received: 302
19 Jan 2023 19:32 #46698
Replied by Terry Cockerell on topic Center Header Bow latch question
Tom that is the part I have a Factory drawing of. I can try taking a photograph of the picture then uploading it to the Forum.
- Thomas Wilcock
- Thank you received: 8
19 Jan 2023 12:45 #46697
by Thomas Wilcock
Replied by Thomas Wilcock on topic Center Header Bow latch question
19 Jan 2023 08:31 - 19 Jan 2023 08:36 #46696
This is probably the brass plate referred to.
Sorry the file will not open when I attach it.
Last edit: 19 Jan 2023 08:36 by Terry Cockerell. Reason: Adding drawing
15 Jan 2023 13:11 #46684
by pete kelly
Replied by pete kelly on topic Center Header Bow latch question
The latch is correct but there is a larger brass plate to which it attaches.
The following user(s) said Thank You: 1748 S, wolfpline
15 Jan 2023 03:16 #46683
I don't have a phaeton but do have some copies of Factory drawings that were taken over by the Hupmobile Company.
Attached is a drawing of the latch which appears to be identical to yours.
The following user(s) said Thank You: wolfpline
- wolfpline
15 Jan 2023 02:55 - 15 Jan 2023 02:55 #46681
by wolfpline
Center Header Bow latch question was created by wolfpline
Last edit: 15 Jan 2023 02:55 by wolfpline.
