Lockheed Brakes
  • 1748 S
  • Platinum Member
09 Aug 2022 22:34 #45843 by 1748 S
Replied by 1748 S on topic Lockheed Brakes
Thanks very much George for the cup part numbers and the dimensions I will pass this one. It sure will help.
Gary Parsons.
  • George van Nostrand
09 Aug 2022 20:59 #45842 by George van Nostrand
Replied by George van Nostrand on topic Lockheed Brakes
Lockheed wheel cylinder cups :
Front 1 3/8" , FC-857, 1" FC-1499.
Rear 1 1/4" FC-666, 1 "FC-1499.
Lockheed also supplied expander cups.
Reference Wagner catalog 1944.
09 Aug 2022 14:05 #45840 by wcoye
Replied by wcoye on topic Lockheed Brakes
Terry's post is right on. I just had my brakes worked on and the cylinders kept leaking until I passed Terry's drawing on to my mechanic.
Bill
Bill Coye
Westchester 2240A
Brag line: Winner of the
09 Aug 2022 14:05 #45839 by wcoye
Bill
Bill Coye
Westchester 2240A
09 Aug 2022 14:05 #45838 by wcoye
Bill
Bill Coye
Westchester 2240A
09 Aug 2022 14:05 #45837 by wcoye
Bill
Bill Coye
Westchester 2240A
09 Aug 2022 14:05 #45836 by wcoye
Bill
Bill Coye
Westchester 2240A
09 Aug 2022 14:05 #45835 by wcoye
Bill
Bill Coye
Westchester 2240A
  • Terry Cockerell
  • Elite Member
09 Aug 2022 09:10 - 09 Aug 2022 09:11 #45833 by Terry Cockerell
Replied by Terry Cockerell on topic Lockheed Brakes
You should be able to buy the wheel cylinder rubbers separately. From memory the sizes are 1" and 1 1/4" diameter. The first set I bought here in Australia did not have a defined sharp edge but had a round moulding near the edge. These leaked and were not suitable. I was able to find rubbers with a well defined sharp edge as per the originals which worked properly and did not leak.
See the attached sketch.
Last edit: 09 Aug 2022 09:11 by Terry Cockerell. Reason: Adding sketch
  • john mccall
09 Aug 2022 01:22 #45829 by john mccall
Replied by john mccall on topic Lockheed Brakes
Pat,
I checked with the local NAPA today trying to get rebuild kits for my 810. They had them listed, but they were out of stock and could not be ordered. Didn't ask about 812 kits .
  • Pat Leahy
29 Jul 2022 00:29 #45760 by Pat Leahy
Replied by Pat Leahy on topic Lockheed Brakes
NAPA should have kits available. The step bore cylinders were also used in late 30's Ford "juice" brakes.
Pat Leahy
28 Jul 2022 19:02 #45758 by [email protected]
Replied by [email protected] on topic Lockheed Brakes
Ah ! The bore sizes are cast on the cylinders, two sizes which I can't remember. I found generic seals form a classic spares place here in the UK , like super cheap. Worked perfect, just check your bores are good .Gave mine a light hone .
  • 1748 S
  • Platinum Member
28 Jul 2022 04:07 - 28 Jul 2022 04:08 #45756 by 1748 S
Lockheed Brakes was created by 1748 S
Where can the Lockheed brake wheel cylinder repair kits be purchased?
Thanks, Gary Parsons
Last edit: 28 Jul 2022 04:08 by 1748 S.
