- Thank you received: 238
Plug Wire Color
- Frequent Forum Contributor
25 Mar 2022 02:14 #45066
Replied by Terry Cockerell on topic Plug Wire Color
Thanks Tim, I think the colour you are referring to is called zinc chromate.
There were still traces of it on my carburettor.
- wynlaidig
- Thank you received: 32
25 Mar 2022 03:03 #45067
by wynlaidig
Replied by wynlaidig on topic Plug Wire Color
Josh's article was "Color it Yellow", printed in the 2001 No. 5 Newsletter. He said that it seemed that the EE-15 bodies were dipped in dichromate that gave it a "golden-yellow-greenish" color when new. His conclusion was: "Looks like for unsupercharged 810 anb 812 Cords at least, the correct color for the carburetor is golden-yellow-greenish."
- Thomas Wilcock
- Forum Contributor
25 Mar 2022 11:44 #45070
by Thomas Wilcock
Replied by Thomas Wilcock on topic Plug Wire Color
Terry is correct. It is a zinc chromate finish. My carb had some of the original finish on it. I had the body re plated when I rebuilt the carb. attached is picture of finished carb.
- pneflyer
- ACD Club Member
25 Mar 2022 14:43 #45074
by pneflyer
Replied by pneflyer on topic Plug Wire Color
You can get zinc chromate primer on Amazon or any of the aircraft/pilot supply sites. i.e., aircraft spruce
- Thank you received: 162
29 Mar 2022 02:35 #45086
Replied by mikespeed35 on topic Plug Wire Color
The top cover on your carb. looks warped. If you haven't started using it yet it might leak.
29 Mar 2022 04:13 - 29 Mar 2022 04:16 #45087
Mike most of those carburettors would have ended up with the float chamber top distorted due to the screw pattern. I had been told to bend the sides down but kept clear of literally doing that. Instead I made up a sheet metal cover plate that puts gentle pressure on the corners as the three screws are tightened. It sort of blends in.
I had also painted the carburettor silver as zinc chromate plating is not available here.
Last edit: 29 Mar 2022 04:16 by Terry Cockerell. Reason: Adding pictures
Time to create page: 0.255 seconds
