- Thank you received: 7
Cord 810-812 Temp gauge
- [email protected]
25 Oct 2021 18:42 #44176
by [email protected]
Replied by [email protected] on topic Cord 810-812 Temp gauge
It has always worked, I was going to do that just for inquisitive purposes, just to see the difference.
- Thank you received: 302
24 Oct 2021 23:38 #44172
Replied by Terry Cockerell on topic Cord 810-812 Temp gauge
I can't offer any explanation. Try monitoring the temperature with a thermometer in the radiator and comparing it with the gage as she rises.
- [email protected]
24 Oct 2021 16:39 #44169
I tried it and straightened out any kinks, still much the same, possibly the fluid doesn't go all the way to the bottom and completely disappear.
23 Oct 2021 21:20 - 24 Oct 2021 00:13 #44166
Trevor sounds like you have a different problem as your gauge is in your car which you have been driving.
Mine had been out of the car for a number of years during the restoration and I had straightened out some tight bends in the line. George's car is another that has been under restoration.
Let's hear what you uncover.
Last edit: 24 Oct 2021 00:13 by Terry Cockerell. Reason: Revising text
- [email protected]
23 Oct 2021 17:15 #44165
I looked at mine and it reads 100 degrees when cold too. So I guess looks hotter than it really is when running. Dip the probe in a pan of boiling water ? Gonna give it a go !
- George van Nostrand
- Thank you received: 35
22 Oct 2021 21:16 #44163
by George van Nostrand
Replied by George van Nostrand on topic Cord 810-812 Temp gauge
Thanks Terry , I'll try that.
22 Oct 2021 05:49 - 22 Oct 2021 09:30 #44162
Hi George after refitting the temperature gauge in "Our Cord" the red fluid was up on the scale at ambient temperature. I can't remember where I read this but the solution was to place the cylinder head probe in a container of boiling water and then leave it. The system restored itself with the red fluid eventually dropping back to the bottom of the scale.
The gauge has worked perfectly since starting the completely rebuilt engine recently.
Last edit: 22 Oct 2021 09:30 by Terry Cockerell. Reason: Revising text.
22 Oct 2021 03:37 #44161
Replied by 1748 S on topic Cord 810-812 Temp gauge
The number plate with the stripes on it can be moved up or down but very slightly. Tomorrow morning I may be able to post up some pictures because my temp gage is apart till from restoration.
22 Oct 2021 00:44 #44158
Cord 810-812 Temp gauge was created by George van Nostrand
My 810 temperature gauge registers 100 degrees F when cold at 60 degrees F room temperature Has anyone re-calibrated this gauge, as Auburn did ?
It has been installed.
