Headlights stopped working
- JEFF.SIGLER
- Junior Member
02 Jun 2021 12:26 #43283
by JEFF.SIGLER
Replied by JEFF.SIGLER on topic Headlights stopped working
Thank you for the reply! I found the problem and now have lights!
- JEFF.SIGLER
- Junior Member
02 Jun 2021 12:26 #43282
by JEFF.SIGLER
I found the problem to be a short in the relay box cover. Now I have headlights!
- JEFF.SIGLER
- Junior Member
02 Jun 2021 12:24 #43281
by JEFF.SIGLER
Thank you for the reply. Shortly after posting my problem I found a short in the replay box cover. A little cork gasket material solved the problem!
- Thank you received: 117
01 Jun 2021 22:23 #43274
by pete kelly
Replied by pete kelly on topic Headlights stopped working
NO GROUND
- Ivor
01 Jun 2021 22:21 #43273
by Ivor
Replied by Ivor on topic Headlights stopped working
Hello Jeff, you may have a poor connection in the switch or the wiring and when a load is applied it causes the volts drop to near zero. If you do not have time to trace the fault you could run a temporary circuit for your night time event.
- JEFF.SIGLER
- Junior Member
01 Jun 2021 21:22 #43272
by JEFF.SIGLER
Headlights stopped working was created by JEFF.SIGLER
My 810's headlights stopped working suddenly and I can't figure out the issue. I've purchased replacement 6v H6006 bulbs which is what was in it and none of the four I purchased work. I tested the voltage at the terminals and I'm getting 6+ volts at all three connectors. The fuse is fine. Any clue what could be wrong? I'm driving my niece at her wedding and really need the lights!
