- Thank you received: 302
Period Style Hose Clamps
- Elite Member
11 May 2021 01:27 #43124
Replied by Terry Cockerell on topic Period Style Hose Clamps
Thanks Curt, I ended up making eight clamps of varying size. The rest that I had bought fitted ok.
10 May 2021 23:04 #43123
Replied by Curt Schulze on topic Period Style Hose Clamps
If they are the same size as Auburn I have some.
10 May 2021 18:36 #43117
Replied by johnmereness on topic Period Style Hose Clamps
Terry, the original hose clamps are thicker in metal than reproductions, hard to find nice plated originals, "wonky" sizing on them via period hoses and modern day hoses, and ... - it is going to be (and usually is) a project that eats a lot of time and shipping money matched to aggravation.
- Elite Member
09 May 2021 09:20 - 09 May 2021 09:21 #43100
It is amazing how each problem can grow. The hoses I bought were the real problem as they have a thinner wall thickness than the original hoses, consequently the normal clamps will not close up enough in some cases.
The Restoration Supply Catalogue did not cover all of my needs.
Solution .................... make special clamps to suit. The small "C" shaped strip in the attached pictures bridges the gap below where the screw and nut are fitted.
Last edit: 09 May 2021 09:21 by Terry Cockerell. Reason: Adding pictures
- Elite Member
05 May 2021 00:32 #43051
Quite an incredible range of products. I have also been looking for small diameter S/S flexible conduit for the Fog Lamps .......... they have that too.
Thanks, Terry.
Thanks, Terry.
- Mike Brady
04 May 2021 23:20 #43049
by Mike Brady
Replied by Mike Brady on topic Period Style Hose Clamps
Restoration Supply Company has them for $5 - $7.00 each. Page 15 of their current catalog (which you will need to download).
- Elite Member
04 May 2021 21:20 #43048
Period Style Hose Clamps was created by Terry Cockerell
Where can I purchase period style hose clamps to suit a Cord V8 engine?
The attached picture shows the general type of construction.
