WINDSCHIELD WOOD
07 Apr 2021 20:14 #42858
Replied by Terry Cockerell on topic WINDSCHIELD WOOD
It is the edge strip material that fits along the bottom of the headlining above the windshields.
It has a U shaped woven wire inside it so that it can be opened up for fixing in place with tacks etc then closed back up. It is also used around the door openings. It is also called wind lacing.
- wynlaidig
- Thank you received: 44
07 Apr 2021 12:24 #42855
by wynlaidig
Replied by wynlaidig on topic WINDSCHIELD WOOD
Can I ask a dumb question? What is a "wire on" ?
- A.S. KOLLER
02 Apr 2021 23:39 #42812
by A.S. KOLLER
Replied by A.S. KOLLER on topic WINDSCHIELD WOOD
Thanks Terry, the drawing is very helpful and not what I expected.
I thought that the back of the stick would have a V-cut to match the windshield post. The 1/2" radius cut is a lot easier to make but it does leave a gap that I don't care for on both edges.
The 1/2" radius cove on the top edge appears to be upside down or am I
mistaking?
In order to install the wire-on in one piece I would have to modify the bridge piece of wood in that area which I am not sure I should do. I will e-mail you a picture of it as I do not know how to attach pictures in this forum.
Thanks Steve
mistaking?
Thanks Steve
01 Apr 2021 22:26 - 01 Apr 2021 22:29 #42799
Steve attached is a copy of the original Trim Stick Factory drawing. The wired on strip can be installed in one piece.
Note that the location of the rear view mirror was set higher in the Hupmobile version. The Cord height was 2 29/32", you could round this off to 2 7/8"
Last edit: 01 Apr 2021 22:29 by Terry Cockerell. Reason: Adding drawing.
- A.S. KOLLER
01 Apr 2021 21:01 #42798
by A.S. KOLLER
WINDSCHIELD WOOD was created by A.S. KOLLER
Hi,
I need to make the piece of wood that goes between the V in the windshield on an 812 Beverley.
My question is, does the wire-on go across the windshield in one piece with the wood routed out to go over it or is the wire-on split and butt against the edge of the center piece of wood?
Steve Koller
Steve Koller
