Clutch Switch
  • alsancle
  • alsancle's Avatar Topic Author
  • ACD Club Member
  • ACD Club Member
01 Apr 2021 14:29 #42786 by alsancle
Clutch Switch was created by alsancle
Could someone point me in the direction of where the Clutch Switch is located? I didn't want to pollute the selection switch wiring thread anymore than I have, but I'm trying to pull the selection harness to the front of the car following the original one. First problem is the red wire from the old harness comes out of the selection harness and is wrapped in to another set of wires. The Red wire goes to the clutch switch and powers the entire setup.
See my picture. What fun.
01 Apr 2021 14:59 #42788 by uconn_1965
Replied by uconn_1965 on topic Clutch Switch
I couldn’t attach photo to this reply. I shared a photo of red wire to clutch switch but it appears under the club information tab. Hope this helps
  • alsancle
  • ACD Club Member
  • ACD Club Member
01 Apr 2021 15:50 #42790 by alsancle
Replied by alsancle on topic Clutch Switch
uconn_1965 wrote: I couldn’t attach photo to this reply. I shared a photo of red wire to clutch switch but it appears under the club information tab. Hope this helps
I looked under the "club info" tab but was not sure where to go. Is it in one of the boattail newsletters?
01 Apr 2021 16:24 #42791 by uconn_1965
When I log in, I click on forums, read more. The very first category is club information and that is where the photo of clutch switch and red wire is located or send me your email address and I’ll send it directly to you. Cliff
  • alsancle
  • ACD Club Member
  • ACD Club Member
01 Apr 2021 16:30 #42792 by alsancle
Thanks. I got it. So this is looking down on drivers side of car right next to master cylinder. This car doesn't have a cage so things look a little more open.
01 Apr 2021 16:34 #42793 by uconn_1965
Yes you are correct. For orientation, look at the dip stick and the nut cover for master cylinder. That would be the same position or location on all Cords, opened or closed, non S/C or S/C.
Time to create page: 0.233 seconds
