- Thank you received: 44
Wheel Lugs
- wynlaidig
- Tim Gilmartin
- Thank you received: 57
Tim.
- alsancle
They do seat much better than the originals.
- alsancle
- George van Nostrand
- Thank you received: 34
is a good spec.
- Tim Gilmartin
Tim.
- Elite Member
- Thank you received: 301
- Premium Member
Cliff - with a 4' lever on the socket and guessing you are putting your weight of 100 to 150 lbs on the end of the lever which means you are putting between 400 and 600 ft-lbs of torque on the lug bolts. I don't have my charts handy but that is way too much torque. just my 2 cents.
- alsancle
- alsancle
alsancle wrote: Peter Morgan gave me a call and explained what was going on here. I short term fix is that NAPA has lug bolts with a 7/8 head instead of the factory 3/4.
www.napaonline.com/en/p/NDP6411587
Thats actually a great idea from Peter. I may try a couple of these lug nut bolts just to see how they fit.I doubt using these are going to drop us a few points in judging. How would any judge really know these were on a car.
- alsancle
- alsancle
thanks.
A.J.
- Elite Member
I had my original cast hubs crack tested and was horrified to see they were full of cracks. The steel hubs are the only way to go for safe driving.
- alsancle
- alsancle
Thoughts?
