- Thank you received: 33
Spare Tire Shelf
- john mccall
01 Apr 2021 02:38 #42783
by john mccall
Replied by john mccall on topic Spare Tire Shelf
It's not the same. As I recall it has a hinge toward the rear section that allows it to drop down at an angle toward the spare. I thought I had info from Rick Hulett that showed the basic outline but it only covered the Westchester and Phaetons which used the same basic board with relatively small modifications.
- Thank you received: 302
30 Mar 2021 21:55 - 31 Mar 2021 05:51 #42765
Replied by Terry Cockerell on topic Spare Tire Shelf
Gary I have no idea if the Beverly shelf was deeper. Looking at pictures in Google Images the Beverly may have a hinged section to increase the depth which will fold back to allow the spare wheel to be removed.
Quite a few years ago I made a drawing of my Westchester shelf.
Attached is a copy.
Attached is a copy.
Last edit: 31 Mar 2021 05:51 by Terry Cockerell. Reason: Adding picture
30 Mar 2021 13:51 #42763
Spare Tire Shelf was created by 1748 S
what are the dimensions for the spare tire shelf in a Beverly sedan? Is it the same size as the Westchesters?
Thanks...
Thanks...
