Safe jack points?
27 Mar 2021 01:29 #42738
by uconn_1965
Replied by uconn_1965 on topic Safe jack points?
At rear you can jack up under the center of rear spring on each side and place the jack stand outboard as far as possible on the axle. Be careful not to crimp the copper brake line that runs along the axle
- alsancle
- Thank you received: 15
27 Mar 2021 00:40 #42737
by alsancle
Thanks. I used the center of the front spring, but do not see any convenient spot in the rear.
Replied by alsancle on topic Safe jack points?
uconn_1965 wrote: Don’t jack up the rest at the center point of the axle, you can bend it.. in the front I jack up under the center of front spring and place the jack stand under the stub frame where ever convenient.
27 Mar 2021 00:37 #42736
by uconn_1965
- alsancle
27 Mar 2021 00:18 #42735
by alsancle
Safe jack points? was created by alsancle
Because I sadly don't have a lift I need to get our 812 Convertible coupe up high on jack stands. In the front the spring perch looks like a solid spot, but in back I'm not sure. I don't like the look of the axle and I'm thinking jacking from the center of it might be a bad idea.
Does anyone have any suggestions?
