What is this Cord engine transmission setup?
24 Mar 2021 18:38 #42713
I posted this picture hoping some of the well informed Cord guys may have more information than just my picture. It appears someone designed some very interesting engine trans water pump modifications besides the re location of the batter. BTW I certainly would never place a battery that close to the hot engine. I learned something about batteries many years ago. An owner of a Dodge pickup truck kept boiling out his single battery. After much investigation and parts change out like alternator... turns out the battery ground was connected directly to the exhaust manifold bolt. So the copper ground wire transferred heat enough to boil battery acid....
Replied by 1748 S on topic What is this Cord engine transmission setup?
Red Brick wrote: Interesting. What Cord is this?
Where is it?
Who owns it?
Any photos of the interior?
Is it shifted via the Cord column-mounted shifter?
Is it still being driven?
Also, I see the battery is now under the hood.
- Red Brick
24 Mar 2021 05:56 #42711
by Red Brick
Replied by Red Brick on topic What is this Cord engine transmission setup?
Where is it?
Who owns it?
Where is it?
Who owns it?
23 Mar 2021 14:14 #42698
What is this Cord engine transmission setup? was created by 1748 S
This Cord appears to have an automatic trans by the exposed flywheel. The water pump has been moved towards the radiator and the generator has been re-positioned to the radiator end too.
