- Thank you received: 301
Shift Switch
- Elite Member
20 Apr 2021 10:50 - 20 Apr 2021 10:52 #42922
Replied by Terry Cockerell on topic Shift Switch
Sarah, have a look at Page 2 of the Gear Selector Switch Wiring topic.
Towards the bottom of the page are some good pictures.
Last edit: 20 Apr 2021 10:52 by Terry Cockerell. Reason: Revising Text
- [email protected]
- Junior Member
20 Apr 2021 08:39 #42921
by [email protected]
Replied by [email protected] on topic Shift Switch
Still working on the shift switch. New wafer has arrived today. Looking at the article from the club magazine the spring that gives pressure on the wafer switch Is way shorter than the one i have. Can anyone give me the length, wire size of what the spring should be
- [email protected]
- Junior Member
15 Apr 2021 08:03 #42905
The wafer was damaged and I have a new one on the way. Temporarily fixed the old one. The finger change was also very badly worn, you didn't have to lift to engage reverse ,so have made a new one
- Elite Member
17 Mar 2021 04:41 #42637
Hi Paul, there should still be available a book on the gear box from the Museum in Auburn. It was written by Sid Ayres. It is also being currently updated and reprinted. Jim O'Brien would be the best contact for the new book.
Jim's new email address is
[email protected]
[email protected]
- [email protected]
- Junior Member
16 Mar 2021 21:57 - 17 Mar 2021 02:30 #42632
Excellent, thanks Terry. You mentioned there is a booklet on the gear box available from the Museum in Auburn. There is no specific gearbox booklet available on their website, we have purchased the owners manual and service manual from them which are currently on the way to us. Any recommendations on where we can purchase any manual specific to the gearbox? Regards Paul (Sarah's husband)
Last edit: 17 Mar 2021 02:30 by [email protected].
- Premium Member
16 Mar 2021 01:01 #42629
Replied by JIM.OBRIEN on topic Shift Switch
Hi Sarah, Congratulations on your "new" Cord. First I would look at the cross shift and see if when you put the selector switch in 4th gear does the cross shift move to the right? If the cross shift doen't move check the power at the solenoid. if not the problem is up in the selector switch.
If the cross shift does move, check the #5 wire on the cross shift switch and see if there is power there. If there is no pwer then you need to adjust the switch. If there is power check the solenoid. Sorry I don't have my wiring diagram with me so I don't remember whcih wires on the solenoid bank.
This will isolate where your problem is. Good luch and let us know how you make out. I guess I should ask do you have the shift wiring diagrapham?
The following user(s) said Thank You: [email protected]
- alsancle
15 Mar 2021 12:30 #42628
by alsancle
Replied by alsancle on topic Shift Switch
Your issue is not uncommon. Jim's article is gold and must be studied. There are also some threads on here that you should probably read front to back. This is one:
phpstack-1081784-3880776.cloudwaysapps.c...lector-switch-wiring
- Elite Member
15 Mar 2021 08:58 - 15 Mar 2021 10:42 #42627
It seems you have developed a loose connection .................. somewhere.
It may be up front on the gear box, the gear change switch or somewhere in between. It will be a step by step process of elimination.
Attached are copies of the pages you requested.
There is a booklet on the gear box available from the Museum in Auburn.
Last edit: 15 Mar 2021 10:42 by Terry Cockerell. Reason: Adding pictures
- [email protected]
- Junior Member
15 Mar 2021 06:19 - 15 Mar 2021 06:57 #42626
Shift Switch was created by [email protected]
We are new cord owners. It seems sometimes we can engage 4th gear, sometimes it needs a wiggle then engages, sometimes no one home. Any ideas? I have the latest cord mag with part 2 on shift switch but can anyone scan part 1. I am happy to buy a back issue but it will take weeks to get to us in NZ. Any suggestions appreciated.
Last edit: 15 Mar 2021 06:57 by [email protected].
