Shift Switch
15 Mar 2021 06:19 - 15 Mar 2021 06:57 #42626 by [email protected]
We are new cord owners. It seems sometimes we can engage 4th gear, sometimes it needs a wiggle then engages, sometimes no one home. Any ideas? I have the latest cord mag with part 2 on shift switch but can anyone scan part 1. I am happy to buy a back issue but it will take weeks to get to us in NZ. Any suggestions appreciated.
Last edit: 15 Mar 2021 06:57 by [email protected].
  • Terry Cockerell
  • Terry Cockerell's Avatar
  • Frequent Forum Contributor
15 Mar 2021 08:58 - 15 Mar 2021 10:42 #42627 by Terry Cockerell
Replied by Terry Cockerell on topic Shift Switch
It seems you have developed a loose connection .................. somewhere.
It may be up front on the gear box, the gear change switch or somewhere in between. It will be a step by step process of elimination.
Attached are copies of the pages you requested.
There is a booklet on the gear box available from the Museum in Auburn.
Last edit: 15 Mar 2021 10:42 by Terry Cockerell. Reason: Adding pictures
The following user(s) said Thank You: [email protected]
15 Mar 2021 12:30 #42628 by alsancle
Replied by alsancle on topic Shift Switch
Your issue is not uncommon. Jim's article is gold and must be studied. There are also some threads on here that you should probably read front to back. This is one:
www.acdclub.org/forum/cord-810-812-acd-f...lector-switch-wiring
  • JIM.OBRIEN
16 Mar 2021 01:01 #42629 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic Shift Switch
Hi Sarah, Congratulations on your "new" Cord. First I would look at the cross shift and see if when you put the selector switch in 4th gear does the cross shift move to the right? If the cross shift doen't move check the power at the solenoid. if not the problem is up in the selector switch.
If the cross shift does move, check the #5 wire on the cross shift switch and see if there is power there. If there is no pwer then you need to adjust the switch. If there is power check the solenoid. Sorry I don't have my wiring diagram with me so I don't remember whcih wires on the solenoid bank.
This will isolate where your problem is. Good luch and let us know how you make out. I guess I should ask do you have the shift wiring diagrapham?
16 Mar 2021 21:57 - 17 Mar 2021 02:30 #42632 by [email protected]
Replied by [email protected] on topic Shift Switch
Excellent, thanks Terry. You mentioned there is a booklet on the gear box available from the Museum in Auburn. There is no specific gearbox booklet available on their website, we have purchased the owners manual and service manual from them which are currently on the way to us. Any recommendations on where we can purchase any manual specific to the gearbox? Regards Paul (Sarah's husband)
Last edit: 17 Mar 2021 02:30 by [email protected].
  • Terry Cockerell
17 Mar 2021 04:41 #42637 by Terry Cockerell
Hi Paul, there should still be available a book on the gear box from the Museum in Auburn. It was written by Sid Ayres. It is also being currently updated and reprinted. Jim O'Brien would be the best contact for the new book.
Jim's new email address is
Time to create page: 0.328 seconds
