810 Engine parts
14 Mar 2021 15:26 - 14 Mar 2021 15:28 #42625
Replied by mikespeed35 on topic 810 Engine parts
The harder the babbit the more technique sensitive it is to solder. I had some hard babbit fail because it was improperly soldered. This failed babbit was NOT done by Paul's.
Last edit: 14 Mar 2021 15:28 by mikespeed35.
- Thomas Wilcock
- Senior Member
- Thank you received: 8
14 Mar 2021 12:41 #42624
by Thomas Wilcock
Replied by Thomas Wilcock on topic 810 Engine parts
I use No.2 babbit which is also called diesel babbit. It is about 92% tin with copper and antimony making up the rest (I forget the percentages). The softer grades of babbit contain various percentages of lead.
Tom
Tom
13 Mar 2021 05:47 #42618
There is more than one kind of babbit. some softer and some harder. Builder seem to have varying opinions as which is best.
13 Mar 2021 05:44 - 13 Mar 2021 05:44 #42616
I also use Paul's. I no longer use insert bearings in non orig. insert bearing cars .
Last edit: 13 Mar 2021 05:44 by mikespeed35.
12 Mar 2021 15:16 #42608
by uconn_1965
Replied by uconn_1965 on topic 810 Engine parts
My engine machinists has had excellent results using Paul’s rod and bearing for pouring Babbitt for rods and cam bearings. There in Parkville, Mo.
6212 N.W. Bell Rd. 816-587-4747.
- E L
- Thank you received: 24
12 Mar 2021 15:07 #42607
by E L
Replied by E L on topic 810 Engine parts
The aaca has some good discussion on the pros and cons of babbit vs bronze
Wear caused from dirt is a concern. I have never tried to use bronze. I also have never had a babbit failure. Todays babbit has better properties then that of the 30's
- Premium Member
12 Mar 2021 01:03 #42600
Replied by JIM.OBRIEN on topic 810 Engine parts
Mike, Yes new email - the old one (cordman) is no longer. Also I no longer have a land line so you have to call my cell phone.
George, for the bronze bearings do you need to open up the clearances to account for the difference in expansion? or what?
- E L
11 Mar 2021 13:02 #42587
by E L
In the past I have always used the old bearing liners and had them re-poured with fresh babbit. The poured liners come back in the rough and then lined bored once installed. Be very careful with bronze as the heat expansion can be an issue. I have seen them fuse to the cam
11 Mar 2021 05:10 #42583
Jim, is this a new email address? Is old one cordman no good?
- Premium Member
11 Mar 2021 02:08 #42580
Hi Grant,
The original cam bearings were poured babbit. Today some people use bronze bearings. They have to be custom made. If you want a set let me know, I have to make a set for my engine so I can make two sets.
I have lot of extra engine parts (as well as other Cord Parts). What do you need? You can PM me or email me at [email protected]
- Grant Amor
- Junior Member
10 Mar 2021 23:56 #42577
by Grant Amor
810 Engine parts was created by Grant Amor
Hi guys we are currently restoring a 810 Phaeton and require cam bearings, and possibly other engine parts also trunk latches can anybody help help with where to obtain these parts
