Gauges background
- Tcheri
- Forum User
23 Feb 2021 08:09 #42367
by Tcheri
Gauges background was created by Tcheri
- Tim Gilmartin
- Thank you received: 34
23 Feb 2021 15:58 #42369
by Tim Gilmartin
Replied by Tim Gilmartin on topic Gauges background
Stan Gilliland used to have them.
- ACD Club Member
- Thank you received: 91
23 Feb 2021 16:40 #42370
Replied by 1748 S on topic Gauges background
I purchased my gauge stencils for the temp and the amp meter from Stan. you will need to repaint everything. Your white paint is wrong for the Cord cars. Its the same color as the yellowish looking background. That color is called Antique White. The numbers are painted on the back of the glass. Use whatever you can cut the paint with like lacqour thinner and a soft tooth brush. Then spray it with the paint. Let is nearly dry. Then scrape it off with a single edge razor blade.The numbers are etched into the back of the glass so it won't be removed when you scrape off the paint. If you do not want to do this work yourself send me a private message to this site or my home email and we can discuss time and cost. You can search this site for my finished dash gauges. Just use my sign on name 1748 S
Time to create page: 0.098 seconds
