- Thank you received: 57
Reproduction horn cap
- Tim Gilmartin
19 Feb 2021 21:58 #42318
by Tim Gilmartin
Replied by Tim Gilmartin on topic Reproduction horn cap
I needed one for my car, as the original tonite threads were worn out.
Got one from Joe. Fits just perfectly.
I had a painter friend do the finish work. He said it sands really easy. He used an epoxy primer, but said acrylic urethane should work also. He wanted to be sure my acrylic enamel color coat would stick.
I recommend Joe’s product.
CORDially, Tim.
CORDially, Tim.
- Pat Leahy
- Thank you received: 27
18 Feb 2021 12:46 #42312
by Pat Leahy
18 Feb 2021 06:16 #42311
Replied by Terry Cockerell on topic Reproduction horn cap
Pat, I remember reading about this project in the newsletter. Joe has done a great job. No doubt other parts will follow.
I was able to repair my original . How much do Joe's reproductions cost?
Regards,
Terry Cockerell
Australia.
Regards,
Terry Cockerell
Australia.
- Pat Leahy
18 Feb 2021 00:55 - 18 Feb 2021 01:55 #42308
by Pat Leahy
Pat Leahy
Reproduction horn cap was created by Pat Leahy
My son, Joe Leahy is now producing excellent plastic horn caps on his 3D printer. Utilizing a special plastic, the parts are printed standing up in pairs. As you can see in photo, even the internal thread is produced and fits nicely without further finishing. While researching the project he found the original steel threaded cups are tapered like a freeze
plugs. Only the outer threads grip tightly, so that is why most failed. He produce a straight plastic cup thread with thin backup washer. Plastic sands nicely and requires minimal cleanup. Let us know if you need one.
Pat Leahy
Last edit: 18 Feb 2021 01:55 by Pat Leahy.
