Wood removal in Phaeton
25 Feb 2021 02:01 #42416
Replied by Terry Cockerell on topic Wood removal in Phaeton
I agree with that George, packing pieces of thick cardboard like the firewall pad was made of were used to fill in any small gaps.
- George van Nostrand
- Thank you received: 35
25 Feb 2021 01:03 #42413
by George van Nostrand
Replied by George van Nostrand on topic Wood removal in Phaeton
Terry From what I can find the factory wood shop made these frames but when they were installed some needed shims. My 810 used a number of them to make it fit the metal work.
24 Feb 2021 20:03 #42405
Your frame can be used for templates. I used a band saw to cut each separate piece then glued and screwed them together just like the original.
- rhauser
24 Feb 2021 17:28 #42404
by rhauser
Replied by rhauser on topic Wood removal in Phaeton
thanks for the reply. I have removed the wood around the trunk but in looking at your photos it looks like this is new wood. Do you have the jigs to make or did you have someone make this for you? I need to replace some of the wood or have a new one made. I also need the piece on the phaeton that goes around the rear tub above the trunk piece.
thanks
thanks
17 Feb 2021 23:41 - 17 Feb 2021 23:42 #42307
Yes, all of the screws and nails are in the flat section where the rubber seal sits.
The rubber seal covers all of the rough stuff.
The attached pictures show the wooden frame assembly for a Westchester.
The layout would be similar for a phaeton.
Last edit: 17 Feb 2021 23:42 by Terry Cockerell. Reason: Adding pictures
17 Feb 2021 22:56 #42306
by uconn_1965
Replied by uconn_1965 on topic Wood removal in Phaeton
I said U shaped bracket but I should have said L shaped bracket. It’s screwed from the outside side of side pieces and bottom side of bottom piece
17 Feb 2021 20:30 #42305
by uconn_1965
Besides the wood screws and nails, the side pieces of wood are attached to the bottom piece of wood with a U shaped brace on each side and I believe you spotted the braces at the top.
- rhauser
17 Feb 2021 20:18 #42304
by rhauser
the only place I saw Screws and nails was on the lip where the trunk lid sits. is that the only place that it is attached? I have removed some of them but it doesn't seem to move at all. The upper wood I do see how it would come out.
17 Feb 2021 19:37 - 17 Feb 2021 19:40 #42303
The wooden frame around the trunk opening is nailed and screwed to the body.
The sedans are done the same way. You can see the holes around the perimeter of the opening which is covered over with a rubber seal.
In the attached picture the wood had already been removed.
Last edit: 17 Feb 2021 19:40 by Terry Cockerell. Reason: Adding picture
- rhauser
17 Feb 2021 16:01 #42300
by rhauser
Wood removal in Phaeton was created by rhauser
I'm still tearing my phaeton done to have the body dipped but I need to remove all the wood so that it doesn't get destroyed. I'm not going to dip the truck lip or upper deck so I'm not asking about those parts . the question is how does the wood in the rear of the car (Primarily around the trunk opening and where the hinges attach for the trunk lid on back deck) attach so that I can remove them. I think I have the wood on the upper side where the hinges attach for the deck lid but I haven't figured out how to remove the wood around the trunk opening. is it glued in or am I missing something.
Robert L Hauser
Robert L Hauser
