Brake Drum Sizes
16 Feb 2021 05:37 #42267
Replied by johnmereness on topic Brake Drum Sizes
Saw a Franklin in a 1929 that the owner was complaining brakes grabbed something awful - when we were all diagnosing it someone put on the brakes and you could see the drum flex - someone did not understand that you cannot just turn the drums down to nothing. I had a similar situation on the 1935 Packard Twelve on one rear drum (unfortunately also a drum hard to come by and a year went into the search).
14 Feb 2021 23:40 #42248
Replied by mikespeed35 on topic Brake Drum Sizes
I have seen brake drums machined so thin that the outer dia. of the drum broke off from the hub part of the drum . Also I have seen a brake adjuster come loose inside a Auburn drum and actually puncture the drum. Neither of these were 810/12 Cords though. Just precautions.
- George van Nostrand
- Thank you received: 35
14 Feb 2021 15:20 #42229
by George van Nostrand
Replied by George van Nostrand on topic Brake Drum Sizes
Maximum oversize is 0.060 ".
13 Feb 2021 21:55 - 13 Feb 2021 21:58 #42223
Replied by Terry Cockerell on topic Brake Drum Sizes
On the subject of brake drums it is a good idea to have them balanced.
With the use of a wheel balancing machine it can be done very accurately.
One of my drums was ok the other three were way out. The worst was out by 120 grams.
Last edit: 13 Feb 2021 21:58 by Terry Cockerell. Reason: Adding pictures
- [email protected]
- Thank you received: 7
13 Feb 2021 20:44 #42219
by [email protected]
Replied by [email protected] on topic Brake Drum Sizes
I have just had mine re-lined , 11" drum and 3/16" shoe thickness I recall. Hopefully some one will confirm.
- [email protected]
13 Feb 2021 20:28 #42217
Brake Drum Sizes was created by [email protected]
We are complying a vehicle in New Zealand, need to supply the original internal diameter of brake drum for Cord 812 Beverly Sedan and maximum allowed machined size. Can anyone help?
