Startix Problems
- A.S. KOLLER
The project car was set up with two batteries when I purchased it.
It was mid restoration with the engine not finished so I have no idea why he added the extra battery.
My understanding however is that while the batteries do have a lot of amps, electrical devices only draw what they need so I don't think that this would be the problem.
If the starter is faulty it could be drawing too many amps causing the problem.
I have ordered an amp clamp to test the draw and will keep you posted
Steve Koller
- Thank you received: 116
Have you tried it with just 1 battery?
- A.S. KOLLER
It is Positive ground and is wired that way.
Any ideas?
Steve
- A.S. KOLLER
When I first started the car I used a standard 6 volt solenoid which after a few starts the contacts welded together, This happened to the second one that I tried.
I then hot wired my startix and used the manual button and the same thing happened.
My car is using two Optima 6V batteries wired in parallel giving a reading of
6.8 Volts and the engine is grounded direct to the battery.
The cables are all heavy six volt cables.
Any ideas?
Steve Koller
- Elite Member
- Thank you received: 301
The article says to leave the generator wire disconnected.
I figure if it is disconnected and taped up inside the Startix box then the generator wire can be connected on the outside to make it look correct.
- Elite Member
Attached is the sheet by Don Beatty showing how to disconnect the restart solenoid.
I have attached a better copy as some of the text had been cut short.
- Premium Member
Would it be possible for you to send me this Startix modification? It sounds interesting and I might want to try it as I restore my Cord.
THanks,
- Elite Member
I'm getting close to finishing the restoration which will probably string out to March 2021 by the time it has been debugged.
I too was wondering that.... Maybe sticks and levers.... I'm sure Terry just has not installed that yet.uconn_1965 wrote: I’m curious. I don’t see a shift arm. How do you shift?
- Elite Member
You will also note a strip with LED lights between the dash and ash tray. These are gear selection lights which are a bit of a novelty but work very well especially with novice drivers.
Red is for reverse and Green covers the Go Gears.
- Elite Member
I covered about 10,000 miles in 5 years and hope to do a lot more.
I had thought the Startix would work without the restart function and without the need of a push button. Thanks again "UCONN".
- Elite Member
Has anybody actually removed the restart solenoid and just used the box with the main solenoid in place ?
By removing the restart solenoid the cable can still be connected to the generator terminal for show.
Any help would be greatly appreciated.
