Gearbox oil
- alsancle
- alsancle
- seltecuae
- Junior Member
visit: www.seltecuae.com/product/automotive-lubricants/gear-oils/
- wynlaidig
- Thank you received: 44
- Rileypu29
- Senior Member
Bill Kastanis
- George van Nostrand
- Thank you received: 34
- wynlaidig
- Tcheri
- Senior Member
Millers Gear Oil Vintage Green 140 GL1 - 1 litre
But as it's a GL1, I have doubts that it's enough in term of EP ? GL4 is much better on that side, but it's never written that it's compatible with yellow metals.
On the other side, the german importer of Lubriplate answered my email and I am now in contact of the shop responsible for France, Belgium and Holland.
Antwerp Lion Oil Works NV
They are selling by 16Kg units for 219€ + transport. With transport, Millers 140W or Lubriplate SPO 277 will be more or less at the same price per litre.
- Rileypu29
- Senior Member
www.rymax-lubricants.com/updates/the-dif...tween-gl-4-and-gl-5/
Bill Kastanis
- Tcheri
- Senior Member
JIM.OBRIEN wrote: Be careful with the oil you put in the Cord transmission. Many of the gear oils today attack yellow metal due to the additive packages they put in the oil. Try and find 140wt gear oil that is safe for yellow metals (brass, bronze).
Yes, avoid GL-5 oils ! GL-1 is probably the most appropriate for old gearboxes, GL-4 for differentials.
- Premium Member
- Tcheri
- Senior Member
ACORDIAN wrote: I says right on the Lubriplate label above that this business operates "world wide". Have you contacted Lubriplate to see where their nearest to you dealer is ?
Also , sounds like you need a friend/advisor near you have you looked at the
Cord members Directory and tried to make a personal connection with a European ?
Yes, they have one German distributor for the "rest of the world" with a website from the 80s , available only in german for the oil part... I will restart from the specifications of that oil to find an european equivalent. We use to have that problem even with more moderns cars, with oils brands and types that are not available from one continent to the other (both way).
I found another friend in Belgium owning a Phaeton SC but his car is serviced in UK. Only few Cord's are registered in Belgium. That make the challenge even more exciting
- ACORDIAN
- Junior Member
- Tcheri
- Senior Member
- Rileypu29
- Senior Member
- Rileypu29
- Senior Member
Best regards,
Bill
Bill Kastanis
- Tcheri
- Senior Member
1748 S wrote: You will find several choices but... I suggest you run the oil Jim Obrien suggests. Also note that the same oil is used in the differential as the transmission.
Thanks, where can I find his recommendation ?
- Tcheri
- Senior Member
Which oil is recommended for the gearbox ?
Thierry
