Head Bolt Lengths
Last is the thread engagement - as a general rule the minimum thread engagement should be 7/16". Check all the holes where the bolt may bottom out to see how much you have from the surface of the block to the bottom of the hole. Make sure you leave a gap and also allow for gasket crush.
The bolt length (blot length is measured from the bottom of the head) you need will be the sum of the washer, head thickness, gasket thickness and thread engagement.
Lastly make sure the threads in the block are good. If there are any questions put threaded inserts in the block.
- twright3
- twright3
- Roads2run
It's been too many years to recall the correct lengths of the Cord head bolts, but let me add a major caution. Cord blocks have been ruined by using bolts extending too far and crushing the inner casting of the block on the far side of the water cavity. Different lengths are used depending on the thickness of the head. E.g. original, Bohnalite, or newly cast. This is in addition to the different lengths depending on what row they are in on the head. Some of the current Cord club members will know. So before putting a bolt in, check the depth of clearance for whatever bolt you use. Tom Hartz
Roads2run
- twright3
- twright3
Tom in San Diego
