Before I bend it !
  • Terry Cockerell
  • Elite Member
18 Aug 2020 08:18 #40755 by Terry Cockerell
Replied by Terry Cockerell on topic Before I bend it !
Graham is must be around 1/4" from memory. I should have measured it when I had the chance. You can unscrew one of the brake tube clamps to get an idea.
  • Blackiron
  • Senior Member
18 Aug 2020 02:08 #40753 by Blackiron
Replied by Blackiron on topic Before I bend it !
Sounds like there may be a few Cords around with positive camber on the rear wheels !. It would be interesting to know what the wall thickness is.
  • Terry Cockerell
  • Elite Member
17 Aug 2020 21:49 #40752 by Terry Cockerell
Jim the guy used a huge trolley jack with the lifting head or cup around 4 to 6 inch diameter. I am glad that it was not a point loading.
What sort of loading was the rear axle subjected to at speed of around 50 mph if one wheel hit a pot hole in the vicinity of 3 to 4 inches deep?
  • JIM.OBRIEN
  • Premium Member
16 Aug 2020 02:09 #40740 by JIM.OBRIEN
Replied by JIM.OBRIEN on topic Before I bend it !
DO NOT jack up the car by the center of the rear axle - IT WILL BEND!
Terry - you got lucky it didn't bend.
  • uconn_1965
15 Aug 2020 13:21 #40734 by uconn_1965
Replied by uconn_1965 on topic Before I bend it !
I’ve always place the floor jack under the rear spring to axle u bolt plate with a safety jack stand in place as close to the jack as possible but the weight being carried by the floor jack . If I’m working on a Cord with Bendix brakes and need to access the slot for brake adjustment, I might lower car onto jack stand and remove floor jack to make it easier to adjust brake shoes. Never had a problem.
  • 1748 S
  • Platinum Member
15 Aug 2020 12:50 #40733 by 1748 S
Replied by 1748 S on topic Before I bend it !
I sure would NOT jack up my Beverly by the center of the rear axle. These cars do have a significant frame under them. I would place a jack under the frame just forwards of the rear leaf springs and lift one side. Adjust the brakes. Or, you can lift each side by using two jacks on the frame rails.
  • Blackiron
  • Senior Member
15 Aug 2020 06:10 #40732 by Blackiron
Hi Terry, someone must have done it, did it bend ?
Wanting to adjust rear brakes without twisting the frame and putting tension on the handbrake cables. I know there are many ways to do it, just curious.
  • Terry Cockerell
  • Elite Member
15 Aug 2020 05:43 - 15 Aug 2020 05:45 #40731 by Terry Cockerell
Graham this was done to my Cord by a lazy panel shop repair guy. I didn't like it being done however if you are concerned that lifting in the centre will distort the axle I think the answer would be no it would't do any real harm.
The axles were subjected to pretty vicious treatment on unmade roads particularly here in Australia as well as not so wonderful pavement. If your Cord handled that you have nothing to worry about.
Normally I use two trolley jacks as I don't have room for a hoist.
Last edit: 15 Aug 2020 05:45 by Terry Cockerell. Reason: Revising text>
  • Blackiron
  • Senior Member
15 Aug 2020 04:48 #40730 by Blackiron
Before I bend it ! was created by Blackiron
Has anyone jacked the rear of their car by lifting at the centre of the rear axle ?
