- Thank you received: 25
Voltage Regulator Issues?
- E L
I do believe the straps should be on the inside however
- Thank you received: 302
Glad to hear you have sorted out your electrical problems.
I have a question for you.
What are the four bolts and two metal straps supporting on the firewall?
The are located above the steering column .
- devinec
I appreciate the advice and help available on this forum!
Craig
- Frenchsic
Ken
- Frenchsic
Ken
- Frenchsic
Ken
- devinec
Uconn_1965... you suggested calling Rich at DJ's Alternator in Connecticut about possibly repairing/refurbishing this regulator. I called them, but unfortunately, Rich has retired. Here's a picture of the regulator guts. Does anyone have ideas about who else might have the skills and knowledge to adjust some part of this to increase the voltage output going to the battery? Any other good sources besides DJ's Alternator?
Thank you!
- devinec
- devinec
Also, if it turns out the voltage regulator is suspect, what's a good source for a voltage regulator? Rebuild or replace?
- devinec
I also dissembled the ignition switch. I found that the bright yellow wire on the right is the wire with the 4 amp draw. I haven't worked to trace it yet... does any know what it's connected to? Thanks again for helping me with this.
Craig
- Thank you received: 19
If I remember correctly the ON position only has the clutch switch on it, there may be others wires depending on how someone wired the car. Try removing this wire and see if the 4 amp draw goes away. It should be a green 12 gauge wire. If there are several wires remove them all until the 4 amp draw goes away. then put them back one by one and see where the draw is.
The more I think about it you may still have a problem with the voltage regulator since even with a 10 amp draw the generator should be able to charge your battery.
- devinec
1) Key on, motor off: -10 amps
2) Key on, motor running: - 10 amps
3) ACC on: 0 amps (motor off)
4) Key on, fuel pump disconnected, motor off: -4 amps
5) Ken on, fuel pump disconnected, motor running: -4 amps
Following restoration in about 1990, car was run/driven alot by PO, so the car has run well in it's past. That would lead me to think that it's properly wired... but not opposed to verifying that as needed. The PO seemed to be honest about the car's strengths issues... I'm currently working through the issues (including shifting... mostly resolved). The only comment about the charging system was... "charge it up once in a while". Not sure what all he meant in that comment.
The fuel pump is definitely drawing amps... with the motor off and motor on. I could disconnect the fuel pump and drive the car abit. But the ammeter still indicates negative even when it's disconnected, so I still feel like I'm not getting the right amount of voltage produced.
I took a picture of wires of the generator feed wire and whether it's touching the brush weather cover... did I get the right view? If I'm looking at the right thing, it looks like a good connection with no grounding.
I'll work to verify good grounding of both the voltage regulator and the generator.
The car has an Optima battery that looks fairly new. I believe it's good, but I have a another brand new Optima battery (that I purchased two weeks ago to have as a backup I carried with me for the excursion last weekend.) I'll can put that battery in.
For your answers to Number 4 - is the engine running at this time? I'm guessing it is since answer #1 says no current draw without the engine running.
You said you had your generator checked out and it is working properly. I guess the first question is since the car is new to you and we don't know the history on it has it been doing this since you got it? If so first I would check out the wiring between the generator and the voltage regulator - make sure someone didn't wire it incorrectly. Also is there a good ground on both the generator and the voltage regulator. Next would be check the voltage regulator to make sure that is working properly.
If your battery is at 6.04 volts it is not fully charged and is not getting charged when you are running.
The other dumb question is the battery good? Have you tested it? What type of battery is it? I just reread your answers and you say the battery dies quickly with the heater or lights on - that shouldn't happen. Josh drove his Cord across the country when his generator died. He charged it up every night and was able to run all day including several starts and a couple of hours into the night with the lights. Check the battery!
- devinec
1) No amps drawn when key on, motor off
2) No amps drawn when ACC on, motor off
3) Car runs strong, so no apparent issues with spark.
4) Electric fuel pump runs when key turned on, ammeter shows -10 amps. I disconnected the fuel pump, then when the key is turned on it shows -4 ams. So the fuel pump is a constant significant draw.
I haven't run it that much, but the battery only seems to die when I have run lights or heater, the big draws. I ran it for two hours a week ago (no lights or heater) and even though it showed negative amps all the while, the battery still has 6.04 amps and I haven't put a charger on it. If I do run lights or heater, the battery dies in a hurry.
I had a mechanic check the generator, and he told me it's putting out good voltage. But he said the voltage isn't getting past the regulator (if I understood him correctly).
Attached is picture of the generator.
Thank you all for the input and discussion.
Second the generator and voltage regulator is not a S/C thing - it is a early vs late. As most things on the Cord it changed over the production at least once, if not two or three times. The early Cords had the three brush generator with the cutout mounted on it. The later Cords (BOTH STANDARD AND S/C ) had the larger generator with the voltage regulator mounted on the firewall. It is very possible even probable they used more then one voltage regulator during the final days of production.
Asking what is on someone's car now will only tell you you what they have on there now, not 85 years ago when the car rolled out of the factory. These are parts that wear out and have been changed over time. People installed what was available, what they had or what worked. Plus for the show cars people put a tag on it and stamped the numbers they felt the judges were looking for.
Also what is listed in the Autolite book or the Motors book are useful guides and indicate what will work but not necessarily what came on the car. For various reasons the lists have changed over time. I have found some of the books give different number in different additions and in some cases are wrong and give incorrect specs. from the very beginning.
Thanks, Gary Parsons
I wouldn't think the voltage regulator would be causing a large current draw on your system. First is there any current draw with the motor off?
How about with the key on but the motor not running?
How about with the Key in the ACC position and the motor not running?
When running are you getting a good strong spark to the plugs?
If none of those tests show any current draw and you have a good spark then look at the voltage regulator. But I would eliminate other possibilities first.
- devinec
What's a good source for a regulator? Or can it be rebuilt?
Thanks for input!
