Rear Licence Plate Holder removal
  • Aris Loumidis
07 Jul 2020 19:46 #40479 by Aris Loumidis
Replied by Aris Loumidis on topic Rear Licence Plate Holder removal
OK all clear now, THANKS!
Aris Loumidis
Athens, Greece
ACD Life Member
______________
1936 CORD 810 Phaeton
  • uconn_1965
07 Jul 2020 19:36 #40478 by uconn_1965
Replied by uconn_1965 on topic Rear Licence Plate Holder removal
As Pete mentioned on earlier post, that small slotted screw holds the bracket for the tag light socket and bulb. You need to pull back the burlap to get access to the 3 screws that hold the tag light housing to the trunk lid . You also need to unplug the wire to the tag light.
The following user(s) said Thank You: Aris Loumidis
  • Aris Loumidis
07 Jul 2020 19:05 #40477 by Aris Loumidis
OK Guys, sorry for the confusion, culpa mea, I was not referring to the licence plate holder, but to the whole Tail Light HOUSING :(
My post should have been titled:
WHAT IS THE SCREW ON MY PICTURE USE FOR?
Followed by this description:
I would like to remove the TAG LIGHT HOUSING assembly so I can paint it, IF POSSIBLE without un-gluing the burlap carpet.
Does any one know what is the purpose of the SINGLE FLAT HEAD SLOTTED screw that I mark on the picture?
Is this screw maybe used to hold the housing onto another bracket underneath it?
P.S Hope this is less Greek to you now!!! :)
Aris Loumidis
Athens, Greece
ACD Life Member
______________
  • Terry Cockerell
  • Elite Forum User
07 Jul 2020 11:57 - 07 Jul 2020 12:02 #40476 by Terry Cockerell
Replied by Terry Cockerell on topic Rear Licence Plate Holder removal
Aris how are you able to attach the rear number plate?
The two screws at the bottom of your picture have nuts on the inside of the trunk lid.
What holds them in place when the screws are removed?
You should have a flat metal strip which the two screws pass through.
You then attach the number plate to the metal strip.
See below in the attached picture.
Last edit: 07 Jul 2020 12:02 by Terry Cockerell. Reason: Adding picture
  • 1748 S
  • Platinum Forum User
07 Jul 2020 00:34 #40475 by 1748 S
Replied by 1748 S on topic Rear Licence Plate Holder removal
pete kelly wrote: Is the licence bracket not held on by 3 screws?
Does not the small screw not hold the bulb bracket in place?
You are correct Pete. I have been away from my car for some time and have forgotten specific things like this.Glad to be corrected by you as a knower more than I..... A relative novice in this restoration.
  • uconn_1965
06 Jul 2020 23:20 #40474 by uconn_1965
You are correct Pete: if tag light housing is on a Westchester trunk lid, You need to pull back the burlap lining on inside of lid to get access to remove the screws.
  • pete kelly
06 Jul 2020 23:10 - 07 Jul 2020 01:10 #40473 by pete kelly
Replied by pete kelly on topic Rear Licence Plate Holder removal
Does not the small screw hold the bulb bracket in place?
Last edit: 07 Jul 2020 01:10 by pete kelly. Reason: 2 notty
  • Aris Loumidis
06 Jul 2020 15:12 #40472 by Aris Loumidis
Thanks for the reply Gary, yes the two chrome screws are to bolt on the licence plate bracket, however to remove the lens in the past, I removed the metal spring-ring that holds it in place so I do wonder what that other flat screw is for.
Aris Loumidis
Athens, Greece
ACD Life Member
______________
  • 1748 S
06 Jul 2020 13:21 #40471 by 1748 S
That screw in the circle is only to remove the lens so you can replace the bulb. The screws you have loosened are how you remove the complete bracket from the trunk. Remember you have a power wire that has to be disconnected too.
  • Aris Loumidis
06 Jul 2020 09:53 #40470 by Aris Loumidis
Rear Licence Plate Holder removal was created by Aris Loumidis
Hi all!
How can I remove the holder without going through the inside of the trunk?
There is a small flat screw as marked on the picture and wonder If by removing it will come off.
I tried it but it wont budge, so before I make some damage, please let me know
Aris
Aris Loumidis
Athens, Greece
ACD Life Member
______________
