851/852 Front Brake Drum's Hub "Felt" Grease Seals Needed...
17 Jun 2020 23:12 #40379
by pete kelly
Replied by pete kelly on topic 851/852 Front Brake Drum's Hub "Felt" Grease Seals Needed...
PM sent
- G-T
17 Jun 2020 21:55 #40378
by G-T
Replied by G-T on topic 851/852 Front Brake Drum's Hub "Felt" Grease Seals Needed...
Well I made some search and found that it seem like Auburn were the only car that came from the factory with those particular Brake Drum style using this "Felt" type of grease seals; they are so damp of oil that this is surprising that nobody had already found an alternative for this problem, Thank You...!!
- G-T
17 Jun 2020 21:48 #40377
by G-T
OK but since the car is a driver regular rubber cover will be fine; Thanks...!!
17 Jun 2020 15:24 #40375
Replied by Curt Schulze on topic 851/852 Front Brake Drum's Hub "Felt" Grease Seals Needed...
34-36 Auburn did not use rubber plugs (covers) to plug the brake adjusting holes. Metal snap in covers were used.
16 Jun 2020 04:12 #40373
Replied by mikespeed35 on topic 851/852 Front Brake Drum's Hub "Felt" Grease Seals Needed...
The brake backing plate rubber covers can be gotten at NAPA, and it is best to replace the spindle seals with modern seals. measure housing and shaft size and check with a bearing Co.
- G-T
15 Jun 2020 23:23 #40371
by G-T
851/852 Front Brake Drum's Hub "Felt" Grease Seals Needed... was created by G-T
I need to replace the (2) front Brake Drum's Grease "Felt" Seals and in the Auburn Factory Parts Book they are part number: E 60579.
I also would like to get 4 small rubber Cover for Brake Back Plate Inspection ( Adjusting) Hole part number: E 10458. Thanks for anny lead to find those parts...!!
