Engine Dust shield's
  • ilikescars
06 Aug 2020 22:24 #40661 by ilikescars
Replied by ilikescars on topic Engine Dust shield's
That is an air deflector, not a dust shield, just so you know....
  • Curt Schulze
22 May 2020 13:37 #40230 by Curt Schulze
Replied by Curt Schulze on topic Engine Dust shield's
They were fabric, some had as much as 1/2 inch hanging out the end (s).
  • johnmereness
21 May 2020 18:40 #40212 by johnmereness
Replied by johnmereness on topic Engine Dust shield's
You will never see the bulk of them - I am fond of glass setting tape. Something in the brown to black range is fine enough, but yes they appear to lean toward black-ish.
  • yorkgulch
  • Premium Forum User
21 May 2020 15:13 #40210 by yorkgulch
Replied by yorkgulch on topic Engine Dust shield's
Most of the scraps of webbing I've found on Auburn frames is black. Is that correct? Most are oil or tar impregnated so I can't tell. One scrap appears brown in the middle.
Auburn 851
  • Curt Schulze
21 May 2020 13:58 #40208 by Curt Schulze
All dust shields are semi-gloss black. There is thin webbing between the frame and the dust shields.
  • yorkgulch
21 May 2020 00:23 #40207 by yorkgulch
Top of Page 83 in 1934 parts book lists 4 pieces of anti squeak for front dust shield and 4 pieces for the side "shield" s?.
Auburn 851
  • yorkgulch
20 May 2020 19:21 #40206 by yorkgulch
Attached are a couple of pictures of an Auburn frame that I don't think the front dust shield has ever been off of. Note the black webbing peaking out around the edges.
Auburn 851
The following user(s) said Thank You: lance@ddclassic
  • johnmereness
20 May 2020 16:18 #40203 by johnmereness
Mine only looks nicer as it is painted in gloss black and that is a double edged sword as I am not sure what finish would be better long term for cleanliness (what does not show water marks and dirt). The original finish was chassis or satin black. As to the webbing - I do not know, but yes, dad's 35 has webbing and the other two cars did not, but then again I was not the first people to touch them. I like to use glass setting tape as webbing.
  • lance@ddclassic
  • Non-Member
18 May 2020 12:11 #40194 by lance@ddclassic
Replied by lance@ddclassic on topic Engine Dust shield's
i am waiting on a parts book for it. I wont have it tlll some time next month from ebay
  • Curt Schulze
17 May 2020 13:33 #40188 by Curt Schulze
Look in the 34 parts book, page 22, there is a blow-up diagram . 34,35,36 are all the same.
  • yorkgulch
16 May 2020 18:58 #40187 by yorkgulch
John yours looks nicer! Should it have body webbing under it like mine? You can see it at the front corners.
Auburn 851
  • johnmereness
16 May 2020 16:59 #40186 by johnmereness
This is actually a photo of the engine splash pan that goes under the harmonic balancer on front of engine. s correct.[/quote]
  • johnmereness
16 May 2020 16:57 #40185 by johnmereness
Thanks, for beating me to the punch, I did not head that way until yesterday.
  • yorkgulch
16 May 2020 15:12 #40181 by yorkgulch
Here's a couple of pictures. Not sure if webbing showing i s correct.
Auburn 851
  • mikespeed35
15 May 2020 04:15 - 15 May 2020 04:16 #40178 by mikespeed35
Replied by mikespeed35 on topic Engine Dust shield's
It also helps to seal the sides of the radiator, although that is not orig. I used pipe insulation slipped over the sides.
Last edit: 15 May 2020 04:16 by mikespeed35.
  • lance@ddclassic
  • Non-Member
14 May 2020 18:10 #40174 by lance@ddclassic
  • johnmereness
14 May 2020 18:00 #40173 by johnmereness
I can photograph, though not heading that way for a few days - if someone can beat me to the punch, please go right ahead.
As a sidenote - the pan in the bottom of the grill must be in place prior to assembly of the grill/hood and is necessary for proper cooling of the car (no exceptions).
  • lance@ddclassic
  • Non-Member
13 May 2020 19:39 #40166 by lance@ddclassic
Engine Dust shield's was created by lance@ddclassic
Anyone have any pictures of engine dust shield's on left side of engine and top cover behind grill shell? I am restoring a 1935 Auburn 851 Salon Phaeton Sedan and its missing the dust shield.
