Rubber Grommet Between Headlight Stand and Headlight Shell (1935-1936)
  • katesmith1304
  • Junior Member
18 Apr 2020 15:07 #39972 by katesmith1304
thank you i was going to arrange some O rings
06 Apr 2020 12:27 #39880 by xjn001
Mc Master Carr will make size to order
  • steve pugh
05 Apr 2020 16:44 #39877 by steve pugh
Thank you. I was going to order some O rings from McMaster-Carr even before I posted this but wasn't sure of the size. I will go ahead and order them and give it a try. Thanks again.
Steve
  • ilikescars
05 Apr 2020 14:18 #39876 by ilikescars
Thickness of the rubber is 1/4". Simply set the O ring onto the stanchion in order to figure out how long it should be and cut a section out. Then glue the ends back together and allow to cure. Because it is oblong, set your new grommet in place onto the stanchion and carefully super glue it in place. {Don't use too much glue} You can also use tape to hold it in place while it dries.
  • steve pugh
03 Apr 2020 04:30 #39872 by steve pugh
Thank you. What is the diameter of the rubber and about how long is the pierce to be glued?
  • ilikescars
02 Apr 2020 22:23 #39871 by ilikescars
I have made these rubber grommets, using an oversized O ring. Simply cut it to the right size and crazy glue the ends together. Works perfectly fine.
  • Curt Schulze
22 Mar 2020 14:09 #39783 by Curt Schulze
Thanks Mike, I am working toward that end.
  • mikespeed35
22 Mar 2020 04:57 #39781 by mikespeed35
Hoping to see you a Auburn this year Curt. Many of us miss you.
  • Curt Schulze
22 Mar 2020 00:06 #39779 by Curt Schulze
After my wife passed away last July , the business closed. I supply parts simply as a favor.
  • pfree3233
21 Mar 2020 03:00 #39770 by pfree3233
Seems like a difficult way to do business for a grommet
  • steve pugh
20 Mar 2020 18:43 #39768 by steve pugh
I am in California so it seems unlikely that I can do that.
  • Curt Schulze
19 Mar 2020 13:31 #39763 by Curt Schulze
The part number is K10655.
Cash and carry : The person comes here, pays me , takes the part home.
  • steve pugh
19 Mar 2020 06:27 #39760 by steve pugh
To be clear, the ones I need are NOT the rubber pad that goes between the fender and the headlight stand. Many people are selling those. How much are the ones that go between the headlight stand and the headlight shell? I am in California. How would you get paid (cash and carry)? My email is [email protected].
  • Curt Schulze
19 Mar 2020 00:20 #39757 by Curt Schulze
I have some, but I sell them cash and carry only.
  • 1748 S
  • Platinum Member
18 Mar 2020 14:43 #39753 by 1748 S
steve pugh wrote: I have spoken to them several times and they have told me that they don't have it. I have also tried Randy Ema, Stan Gilliland, Doug Prey, and Metro Moulded.
Well if you tried all these shakers and movers of the industry. You have ended your search. Last time I talked with Metro about rubber pieces they told me if I could give them an original piece they could make a mold. Sadly I did not have an original. But at least they were willing to work with me.
  • steve pugh
18 Mar 2020 06:12 #39748 by steve pugh
  • mikespeed35
18 Mar 2020 04:54 #39747 by mikespeed35
I have seen these. Try Steele.
  • steve pugh
17 Mar 2020 22:15 #39743 by steve pugh
Does anyone know of a source for the rubber grommet that goes between the headlight stand and the headlight shell on 1935 and 1936 Auburns? If no source is known, does anyone have a drawing or photograph or one so that I would know what it looks like? Thank you for your help.
Steve
