- Thank you received: 18
Parts ID please
- yorkgulch
14 Nov 2019 23:11 #38861
by yorkgulch
Auburn 851
Replied by yorkgulch on topic Parts ID please
There was an ad about 2 months ago . It said they had all supercharger parts. Might have been Frank Cek. Ad had an Ohio address.
Auburn 851
The following user(s) said Thank You: hotrodjohn71
- jrbartlett
14 Nov 2019 22:22 #38860
by jrbartlett
Replied by jrbartlett on topic Parts ID please
Yes, the planetary drive is worn out and needs to be replaced. There are parts available from time to time. I rebuilt the one on my car, and it does make a difference in high-RPM power. You should not attempt to hook up the supercharger in the current condition because it could cause damage to the impeller and the plate beneath it. Of course these engines run just fine even without a functional supercharger.
13 Nov 2019 16:55 #38848
by pete kelly
Replied by pete kelly on topic Parts ID please
There is no clutch.
There is a planetary unit to increase the speed of the impeller relative to the input.
When the planetary is worn it is possible to turn the input but not turn the impeller.
In new or rebuilt condition that is impossible as there is considerable friction in the planetary unit to drive the impeller at speed.
Pete
Pete
- hotrodjohn71
13 Nov 2019 16:11 #38847
by hotrodjohn71
Replied by hotrodjohn71 on topic Parts ID please
Thank you. I have never disassembled this unit. Is there a clutch of some kind between the input shaft and the impeller? The whole mechanism turns freely but I can stop the impeller and still turn the input shaft. Thanks
- rlwardne
13 Nov 2019 00:47 #38840
by rlwardne
Replied by rlwardne on topic Parts ID please
What is your question?
12 Nov 2019 21:50 #38839
by pete kelly
1935 and 1936 Auburn, all body styles
Pete Kelly
Pete Kelly
- hotrodjohn71
12 Nov 2019 21:17 - 12 Nov 2019 21:29 #38838
by hotrodjohn71
Parts ID please was created by hotrodjohn71
Hello. Can you please help me identify this supercharger, the year and model of car? Also, I have a technical mechanical question. Thank you
Last edit: 12 Nov 2019 21:29 by hotrodjohn71.
