Auburn 8/105 CAM Shaft Plunger and new random squeak
- Ivor
25 Aug 2019 22:15 #38099
by Ivor
Replied by Ivor on topic Auburn 8/105 CAM Shaft Plunger and new random squeak
Another possible cause, if the plunger wasn't lubricated during assembly it might have taken some time for oil to reach the rubbing face.
- Ivor
25 Aug 2019 21:46 #38098
by Ivor
This plunger is spring loaded in earlier models and designed to remove all camshaft end play. If same on your model the plunger might be jammed.
- curtiss
- Premium Member
25 Aug 2019 14:52 #38096
by curtiss
Replied by curtiss on topic Auburn 8/105 CAM Shaft Plunger and new random squeak
I reved the engine a few times and the issue went away, hopefully nothing major
- curtiss
- Premium Member
25 Aug 2019 13:16 #38091
by curtiss
Auburn 8/105 CAM Shaft Plunger and new random squeak was created by curtiss
I just got the fresh 8/105 motor installed and running and the first 10 mins were great but now I get a random squeak at idle from the front of the engine so It appears to be coming near the front cover area. I unhooked the belt and still has the squeak with no fan or generator turning.
I am reading in the manual on a Auburn 8/105 the cam shaft play is taken up by the plunger, I assume the plunger is the bump on the end of the cam shaft bolt, correct? Is that adjustable in any way?
It may just take some time for oil to get up there to lube it up.
