water pump fan belt
- GeorgeKathy
- New User
08 Aug 2019 16:59 #37974
by GeorgeKathy
water pump fan belt was created by GeorgeKathy
I have a '32 Auburn 160 A and it has a v belt on it and I am embarrassed to say I can't find a way to adjust it. Should the belt be a link belt instead?
George
George
- rlwardne
- Forum Contributor
08 Aug 2019 19:34 #37976
by rlwardne
Replied by rlwardne on topic water pump fan belt
Not sure about your year but Cord and later Auburn’s the water pump pulley squeezes together to raise the belt. Have to loosen a couple nuts and rotate the pulley sides in opposite directions.
- rlwardne
- Forum Contributor
08 Aug 2019 19:50 #37977
by rlwardne
It
Could also mean time for waterpump bearings and maybe seals
- auburnandyscar
- ACD Club Member
11 Aug 2019 01:23 - 11 Aug 2019 01:24 #37996
by auburnandyscar
Check out my build at:
www.1932auburnsedan.com
Replied by auburnandyscar on topic water pump fan belt
There are 2 (or 3) slots on the pulley with bolts/studs. (I've seen both) loosen the bolts, but do not remove.
One portion is fixed to the Water pump shaft.
The other part can 'slide' to tighten the gap of the "V" , re-tighten the bolts.
**Your belt may be worn/stretched, and the adjustment may already be as tight (travel in the slots) as it can go, so you might need a new belt.
Last edit: 11 Aug 2019 01:24 by auburnandyscar. Reason: spelling
- GeorgeKathy
- New User
12 Aug 2019 16:12 #38006
by GeorgeKathy
Replied by GeorgeKathy on topic water pump fan belt
Thanks so much guys. I have seen centrifugal clutch's that work on that principle but are activated by increasing RPM's. Never thought about it being applied here. There's nothing like a club to help keep old cars running!
George
George
- rlwardne
- Forum Contributor
12 Aug 2019 17:15 - 12 Aug 2019 17:17 #38007
by rlwardne
Depending on how it was treated in the past , they can be a problem to get to move . May need to disassemble and cleanup and straighten. I actually Weld nuts that’s fits a punch on each part to get a good adjustment point
Last edit: 12 Aug 2019 17:17 by rlwardne. Reason: Grammar
The following user(s) said Thank You: 1748 S, GeorgeKathy
Time to create page: 0.126 seconds
