Engine Won't Crank
- yorkgulch
- Forum Contributor
13 Jul 2019 21:00 - 13 Jul 2019 21:03 #37767
by yorkgulch
Auburn 851
Replied by yorkgulch on topic Engine Won't Crank
On the battery auto parts stores used to load test the batteries but don't know is they can do 6 volts anymore. With a starter draw meter that you put on the cable you can tell how much the starter is drawing but dont think you will get a reading till you get past the clicking. The 2 battery set up is battery 1 positive to battery 2 positive to ground on positive ground cars. Battery 1 negative to battery 2 negative then to start it and starter. This in parallel. You get twice the amps but are still at 6 volts. I like adjusting the starting first. But have never had to mess with one.
Auburn 851
Last edit: 13 Jul 2019 21:03 by yorkgulch. Reason: Typo
The following user(s) said Thank You: kenswheels
- Thank you received: 68
14 Jul 2019 04:00 #37771
Replied by mikespeed35 on topic Engine Won't Crank
Before you get too concerned about changes, have you had the battery load tested? Almost any parts store can do that for you free. Have the battery fully charged before having it tested. Might save you a bunch of needless work.
- ACD Club Member
- Thank you received: 66
16 Jul 2019 23:15 #37788
Replied by johnmereness on topic Engine Won't Crank
I will lean toward Mike's advice - the button is a direct contact of power - no button start and most likely no battery to start car with
- kenswheels
Topic Author
- Forum Contributor
17 Jul 2019 17:14 #37796
by kenswheels
Replied by kenswheels on topic Engine Won't Crank
Well, new Optima battery installed and nothing changes. Startix still clicks with the button pushed or when toggle is moved down to STX.
I'm at a loss.
Like I said earlier, it seemed to fade to this point, with the last few starts delayed and becoming weaker, but at least it did crank.
Any more ideas now that the battery has been ruled out?
I'm at a loss.
- ACD Club Member
17 Jul 2019 17:50 #37797
by pete kelly
Replied by pete kelly on topic Engine Won't Crank
Check the draw when the startix button is pushed.
Bypass the startix
Check the condition of the ends of the cables
Pete
Bypass the startix
Pete
- kenswheels
Topic Author
- Forum Contributor
17 Jul 2019 17:53 #37798
by kenswheels
Thanks Pete.
I'm sorry to ask, but could you be more specific? How & where do I check the draw?
To bypass the startix, do I connect the battery directly to the starter?
The condition of the cables...Corrosion, or ?
Thanks for your help!
Time to create page: 0.059 seconds
