How much PSI from a stock Mechanical Fuel Pump for a Supercharged 852?
- G-T
- rlwardne
The real governing factor is if you have too much pressure it will overcome the needle and seat and flooding will occur.
Those pulse or solenoid pumps are available in the under 5 psi range
G-T wrote: I want to back up the mechanical fuel pump on a 1936 Supercharged car so I would need to know what is exactly the original factory PSI spec on it. I've read somewhere that I will be able to run a 12 volts electric pump at 6 volts so it will be easier to find a near perfect match, unless you have a company name and part number that would work just fine for this application. Thanks.
I would be buying a low pressure 6 Volt Fuel Pump. You can run 12 volt pumps on 6 (at least some of them), but it is a crapshoot as to what your results will be as to PSI.
Consider something like this: www.macsautoparts.com/ford_mercury_early...ord-and-mercury.html
- G-T
If you are interested send me a PM with your number, I'll give you a call.
- rlwardne
Backup to the stock
Pump these will flow thru to the stock pump. Some will not let you draw they them
- G-T
