1933 8-105 Timing Chain Install
- Terry
- Terry
when I first saw the pic. What will keep the chain on the sprocket?
Randy and Curt please fill us in.
Pete
curtiss wrote: I am installing the timing chain in the 8-105 and I am a little puzzled. The car was running find when I took it apart (other than the broke ring it had) and the picture below is how the old one was installed, it counts 12 teeth between the marks but the attached manual says it should be 13.
Do I install the new one the way it came out or do I do it as the manual says? What happens if it is a tooth off?
Can someone comment on why this chain does not fill the complete gears and why it does not have a center guide like any other Whitney timing chain? Am wondering if this chain can handle the valve load to open and close valves.
- Terry
- Terry
Hope this helps Terry
- Ivor
- Ivor
- Ivor
- curtiss
