1932 Auburn Cluster gear Bearing
- C.R.D.
22 Jun 2019 21:22 #37578
by C.R.D.
Replied by C.R.D. on topic 1932 Auburn Cluster gear Bearing
Sorry to say, but saw this on the AACA forum today;
George Paul Bachleda, 74, passed away peacefully Sunday, May 26, 2019.
21 Jun 2019 04:12 #37562
Replied by mikespeed35 on topic 1932 Auburn Cluster gear Bearing
Murphy's law, If you sell you will need.
20 Jun 2019 16:50 #37558
Replied by 1748 S on topic 1932 Auburn Cluster gear Bearing
Best idea is take your bearing to a large well known bearing supply. Let them tell you what they have.Many older bearings are no longer available but new designs are. Example is a double shielded bearing can be modified to math a non shielded bearing. You need to know is the bearing a thrust or radial or a mix of these two. In our 36 or 37 Cord front suspension we no longer can source the swing arm inner or outer bearings.Stan figured out like Henry Portz did that we can use 4 single bearings and make a spacer to fit between them. The New Departure 916 center steering arm bearing is still around but no longer make.So some just fab up a brass bushing.I have two of the 916 bearings as spares. I know mine will never wear out too so why am I "hoarding them???
20 Jun 2019 15:19 #37556
Replied by johnmereness on topic 1932 Auburn Cluster gear Bearing
You may want to see if there is a bearing number on bearing itself or ask around like you started doing already hear - then call George @ Olcar Bearing Olcar Bearing Company 135 James Creek Southern Pines, NC 28387 910.693.3324
- ttcinc
19 Jun 2019 10:46 #37539
by ttcinc
1932 Auburn Cluster gear Bearing was created by ttcinc
Anybody have a source for a Cluster Gear Roller Bearing for my Transmission rebuild? .875 ID x 1.375 OD x 1.562 long. Also does anybody know how much End play should be in the transmission when setting up the main drive bearings? Also the counter shaft End play. I do not want to set it too tight. Thank you
