1929 Auburn 680 Engine Rebuild & Other Questions
- IndycarBruce
- IndycarBruce
- IndycarBruce
John, thank you too. So with the old fashioned woven lining, will that wear the drums less than today's stuff?. Like you said, I'll never wear them out because I won't drive every day, but I'd rather reline shoes than try to replace drums that I can't find.
- IndycarBruce
Thank you. I called Fort Wayne Clutch this morning. Looks like they can help me with the brake shoe relining and clutch.
I still have my questions about machine shops for the engine rebuild.
Bruce Wolfe
- IndycarBruce
I have a few questions. I'll start with the engine, which is original. A previous owner told me he wasn't 100% sure, but he thought the engine hadn't been started since the 1950's. So I have no idea what condition it's in. I live just outside of Indianapolis. Does anyone know of a good machine shop in or near Indianapolis who has experience with an engine of this era? I don't know if the block is cracked, so I want someone who knows how to deal with that if needed. I could also go to Ohio if it's within 2 hours of Indy. I also make frequent trips to the Detroit suburbs for work, so I could drop it off during one of my trips. Fyi, I've overhauled 4 car engines in my lifetime, so I'm very mechanical. As long as I have parts, I can put it back together, although I will likely have the machine shop install the pistons so everything is matched well.
While I'm on the engine, am I correct in saying that what I would call the bell housing (where the clutch is housed) is actually and integral part of the engine block, meaning no separate bell housing?
Brakes & Drums: I have the wooden spoked wheels. I haven't pulled any of the wheels off yet, but regardless, I will want the brake shoes relined. I did talk to Auburn Cord Parts in Kansas, and Stan's daughter-in-law said they do that kind of work. But is there a good shop in Indy who could do it? She also said they have kits to rebuild the brake cylinders. Any comments?
Does anyone have the specs on the drums? I don't know how many times the drums have been turned. If one or more doesn't have enough material to be resurfaced, what's the solution? I imagine it's hard to find replacement drums.
Clutch- I want to have the clutch re-lined and checked to see if it should be re-built. Again, Stan's daughter-in-law said they can do that too. Should I send the clutch too them or is there someone in Indy who can do it?
Bruce Wolfe
